Trunk clearance for 645ci vert? - Bimmerfest - BMW Forums
Old 04-15-2013, 08:21 AM
teoulennon teoulennon is offline
Mein Auto: '12 bmw f10
Hi guys,
Just bought a 645ci vert and waiting for it to arrive off the truck
In the meantime, I'm designing a sound system for it but I don't know how tall I can make my subwoofer box.
Can someone tell me the height/clearance of the area between the trunk floor and the bottom of the "shelf" that holds the convertible top?
Old 04-15-2013, 08:41 PM
bump! Anyone mind doing a quick measurement for me?
Old 04-16-2013, 07:21 AM
mattymetzger's Avatar
mattymetzger mattymetzger is offline
Mein Auto: BMW 645ci
29 3/4 " W and 10 1/2 " H.
20" wheels 245/35 - 285/30, black grill and blacked out side markers, 10W white LED angel eyes, Eibach lowering springs on Bilstein shocks,
AC Schnitzer pedals, Sprint Booster (what a waste of money), electronic exhaust cut-outs, red brake calipers (painted)
AFE air intake, door laser BMW logo projector lights, CSR front lip with carbon accents, carbon side skirts
Old 04-16-2013, 07:36 AM
correction
don't make it more than 10 " high, the area right behind the seats is a bit smaller.
I assume you don't want to fold up the shelf, but if you do, the box can not be deeper than 18" (measurement from the back of the seat reaching into the trunk)
Old 04-16-2013, 09:00 AM
Thanks for the help Matt, huge help! You da man!
Old 04-16-2013, 10:10 AM
Mr.GQ Mr.GQ is offline
NO H8TG
Mein Auto: 2008 BMW 650i
Also consider the fact that you will need room to pull the lever down when you want to raise or lower the convertible compartment in the trunk. Unless u plan to keep it open permenantly
Old 04-16-2013, 04:50 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Once you hear the system you probably won't even need a sub. only problem I see is getting to your fuses and battery if you needed to. Make sure you make it easy to take out in case of problems. Remember you have a few electronics modules on the inside of your trunk lid and a few to each side of the trunk sides. Rattling from the sub might affect these modules so be careful.
I just want you to cover your bases before you jump in, don't mean to discourage.
Sent Via iPhone using BimmerApp
Old 04-16-2013, 05:37 PM
if you stay below 18" you can still operate the handle
Nitrogen is right. Wait until you hear the system. For me it is all I need
Old 04-17-2013, 11:27 AM
Thanks for the suggestions guys, I'll be sure to keep them in mind!
I'll be doing an 8" Sundown sa8 w/ around 800w rms () going to it in a .7ft^3 ported box, tuned to 35hz.
The box will be around 10"h x 12"d x 25"w.
I think this will give me the most bump in the smallest package.
I like to feel my music like I'm in the front row of a concert
The only other thing I will upgrade are the tweeters, so I can get silky smooth highs.
I'll post pics of the install when the time comes!
