Old 04-15-2013, 10:35 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
Ventilated Seats - how to use them for the best benefit?
I've had my car for almost a year, and have just found out a different way to use the ventilated seats, that I've never seen mentioned. I've often found their benefit lacking, even on the highest setting, and sometimes can't even tell if they are on. However, today inadvertently, I pulled my back slightly off the seat, and the cooling effect was dramatically better. By having that small air layer between shirt and seat, it allowed a lot more air to flow down between the shirt and seat. It makes logical sense - if you're back is against the seat, there is a limit to where air can flow down. It's just that I've never read about this being a recommendation.
Naturally it's a little strange to drive with your back slightly off the seat, and it's best done when the car is stationary. Does anyone have any thoughts about this approach? Has it made a lot of difference to you?
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 04-15-2013, 02:42 PM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
Hi Chris, that's a great recommendation, I usually have my seat conformed to my back, and I can feel the cooling for a few seconds and then it just seems to go away. I have also found the system cuts down the cooling function from 3 bars to 2 bars automatically, could be another reason for the reduction in air flow,V/r, Tim
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 04-15-2013, 03:18 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Yes, I've noticed same too; best when the top half of multi-contour seats are at their max articulation...
Old 04-16-2013, 07:01 PM
Popoemt's Avatar
I tried your theory out Chris, works great, just a tad uncomfortable as my abs aren't exactly Arnold Schwarzenegger status!
2015 750i
2007 G35 (trade-in)
Old 04-16-2013, 10:33 PM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
These ventilated seats are so weak. I like how it automatically changes from Level 3 to Level 2 after a set amount of time so that you don't get too cold, as if that's even possible. I'd say they're about half as effective as those on the E65.
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 04-17-2013, 04:46 AM
Gundo Gundo is offline
Mein Auto: '11 750i
this is good to hear - I thought mine were malfunctioning. now that temps are rising on the east coast, there must be a better way.
I have heard that the seats cannot cool to a temp lower than what the cabin temp is set to
Also, you can have seats coded to a slightly cooler temperature, and I believe you cannot change duration of fan setting level 3....it's too quick
our Denali will freeze you out of the font seats when cool is on. wish these did the same
Old 04-18-2013, 09:26 PM
FULL 6 FULL 6 is offline
Mein Auto: 2012 750i MSport
I've noticed it makes your farts smell quicker!!
Old 05-12-2013, 10:28 AM
octopump's Avatar
octopump octopump is offline
Brevity = soul of wit
Mein Auto: F10
I can code the seats to function at a lower temp. (they work in conjunction with the A/C). Contact me if interested.
Old 05-12-2013, 06:49 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
You can code to make the air coming out of the seats colder?
Old 05-12-2013, 06:58 PM
octopump's Avatar
Mein Auto: F10
I can code to make the ventilation positions (3-2-1 lights on) correspond to a cooler temp.
Old 05-12-2013, 07:30 PM
coco135's Avatar
coco135 coco135 is offline
Mein Auto: 750i
yes you can code it to a colder temp BUT it doesn't really help, the issue is that when sitting the air flow is being blocked by our body and the (no)strength of the fan is not helping.
i coded mine myself, there is a thread about it on how to and its great when you turn it on for a bit before actually sitting inside the car
Old 05-12-2013, 07:52 PM
octopump's Avatar
Mein Auto: F10
Yes, that's best and then having them is much better than not. The one option I regret I didn't get + I love the look of the seats with perforated leather.
When it comes the air flow being impeded by our body, is the implementation any better in cars from other makes?
I understand fans in BMW < Lexus/ MB, true?
In summer, without the ventilated seats, you could be perfectly comfortable in the cabin with the A/C set at, say 69, but still have a moist/ sweaty back because there is no air circulation there.
Having the ventilated seats (coded or not) allows for a lower temp between the body and the seat just enough not to sweat.
Could you better but it's enough for me.
Old 05-12-2013, 07:53 PM
Can you please post a link to the thread? Thanks!
Old 05-12-2013, 08:06 PM
Snorlax Snorlax is offline
Mein Auto: _
http://www.bimmerfest.com/forums/sho...d.php?t=682664
Read down a bit. The 7 may have slightly different identification of the codes. See near bottom of thread.
Old 05-12-2013, 08:25 PM
octopump's Avatar
Mein Auto: F10
Have a look here: http://www.bimmerfest.com/forums/sho...d.php?t=682664
Edit:
Raj - you beat me to it.
coco135 - you mentioned this makes no difference for you.
Raj - have you coded this to your car? Do you notice an improvement?
Old 05-12-2013, 08:41 PM
Mein Auto: _
Edit:
Have not tried that one yet. May code it tonight if I get a chance.
Thanks, Gentlemen; keep up the good work!
Old 05-12-2013, 09:11 PM
Mein Auto: _
Since you need to put your temp values in hex decimal format. Here is a chart to make to conversion easy for you.
http://www.dewassoc.com/support/msdo...exadecimal.htm
Old 05-12-2013, 10:00 PM
coco135's Avatar
Mein Auto: 750i
Edit:
no, i said once you seating for some time its still not as affective as others like lexus. but if you let it cool for few minutes before you take a seat. it gets freezing! i set it to 16 Celsius
Old 05-12-2013, 10:15 PM
octopump's Avatar
Mein Auto: F10
What is Nexus doing BMW isn't?
Old 05-13-2013, 09:46 AM
coco135's Avatar
Mein Auto: 750i
Nexus is mostly relates to Android phones. but Lexus have stronger direct multiple vents to the seats
Where bmw put a computer cooling fan like and its not direct but a very wide single output
Old 05-13-2013, 11:03 AM
octopump's Avatar
Mein Auto: F10
I was typing on my phone - auto correct...
Good to know. BMW needs to improve its design then. I still think the option is worth getting.
Old 05-13-2013, 11:13 AM
Mein Auto: _
Coded mine last night. Feels a bit better. Placebo effect? Will never know.
Old 05-13-2013, 11:26 AM
I'm also noticing another thing. The leather around the left side of my buttocks is starting to wrinkle. I think it's because of the holes making the leather less durable. I'm going to apply more conditioner to that part, in addition to the bolsters which I have been doing.
2016 Benz C300
Old 05-13-2013, 11:54 AM
Mein Auto: _
Here is exactly where I found the settings in the 2009 F01 as Coco noted. Different than the F10 for those who get frustrating looking for them.
Front Active Seat Ventilation (Cooling):
Front driver seat cushions:
SM [6d]->3002, Sonderausstattung, 2F->Funktionen->KL_T_SOLL_L1
SM [6d]->3002, Sonderausstattung, 2F->Funktionen->KL_T_SOLL_L2
SM [6d]->3002, Sonderausstattung, 2F->Funktionen->KL_T_SOLL_L3
Front driver seat back:
SM [6d]->3002, Sonderausstattung, 2F->Funktionen->KL_T_SOLL_K1
SM [6d]->3002, Sonderausstattung, 2F->Funktionen->KL_T_SOLL_K2
SM [6d]->3002, Sonderausstattung, 2F->Funktionen->KL_T_SOLL_K3
Changed mine to the following settings also:
19(25deg C)
14(20deg C)
10(16deg C)
