2009 650i Sluggish acceleration - Bimmerfest - BMW Forums
Old 04-15-2013, 02:26 PM
astroturf astroturf is offline
Mein Auto: 650i
Hey guys - lately my 650i / auto / 2009 60k has been acting sluggish with acceleration. I can basically place the pedal full to the ground and it will ramp up - smoothly mind you - but no where as fast as it used to. I also notice a slight vibration when idle. Any ideas?
Old 04-15-2013, 02:40 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
I have never had this kind of issue before, but the experts will chime in soon. I'm guessing that if you have an idle issue, you should check your CCV first. The throttle seems like the throttle body could be affected or I'm guessing that the drive-by wire could be affected.
Once a 6'er, always a 6'er.
Old 04-15-2013, 03:25 PM
msa9167's Avatar
msa9167 msa9167 is offline
Mein Auto: 2009 BMW 650I
Any codes???
Old 04-15-2013, 03:56 PM
Mein Auto: 650i
No codes - I don't have a reader. Anyone is LA area have one - willing to pay for a quick diagnostic....
Old 04-15-2013, 05:36 PM
HerbP HerbP is offline
There could be some hidden or part time codes not throwing the CEL light. The 1st thought would be a timing related issue, possibly from the Vanos solenoids. The 2nd thing would be a fuel related problem from partially clogged injectors, or fuel filter problem. It might be in your best interest to have BMW or an Indy pull your codes. This might cost 150.00 or less, but you will know what the problem is. At that point you could have anyone do the repair.
Good Luck!
