Old 04-15-2013, 07:02 PM
jaydp316 jaydp316 is offline
Mein Auto: 2004 bmw x3
'04 BMW X3 AUX wire
Hey everyone, I read something about being able to put a aux input on my 2004 BMW 2.5i X3 and just wanted to see if anyone had any idea if that was possible or where i could find the wire.
The blog i read said something about connecting a wire through the back of the radio but was not sure if that was possible on my model because when i press "mode" there is only option for the CD or the radio no "AUX" display.
Thanks guys
Jay
Old 04-15-2013, 07:07 PM
Mein Auto: 2004 X3 2.5i
http://www.bimmerfest.com/forums/att...4&d=1274460146
The display shows AUX once the $40 cable has been installed. Following the instructions is important, but it's quite simple.
Will work fine in your 2004 as long as no previous owner has messed around with the radio.
Old 04-15-2013, 07:23 PM
Currently my bmw "mode" button does NOT have an option for AUX..will that appear after i have successfully installed the wires?
Old 04-15-2013, 08:09 PM
Yes, I updated my earlier reply. It will, have no fear.
Old 04-15-2013, 08:20 PM
sixspeedz's Avatar
sixspeedz sixspeedz is offline
Mein Auto: 2004 X3 3.0i, 6 Speed MT
I also have a '04 X3 and was looking to do this... Found these directions, checked my software, but it wasn't high enough according to this info... Am I missing something? Can I confirm any other way, given the vehicle was built in 7/2004?
Maybe these instructions are only relevant for e46 business radios?
Head units built date later than 09/02 or with software version 43 or higher can do aux input. The MODE button is not a good enough of an indicator to check if a radio is AUX or Sirius compatible. To check the software version:
1. Turn Radio Off.
2. Turn Radio On.
3. Press and hold the "m" button for about 10 seconds.
4. Press < or > to navigate, you will need to go to the 2nd screen to look for the SW Verison which is in a SV xx-xx xx format.
5. To be Sirius/AUX or XM compatible, the radio must be SW 43 or higher.
6. Turn radio off to exit.
2004 X3 3.0i, MT - REMUS!!!
all upgrades listed in "my garage"
BMWCCA Member - New Jersey Chapter
Old 04-15-2013, 08:50 PM
gaticaag gaticaag is offline
Mein Auto: 2005 X3 2.5i
I just installed an aux cable in my '05 2.5. Really easy and straight-forward. AUX does show after you install. I didn't want my AUX port in the glove box, so I drilled a hole below the climate control faceplate.
Should be able to install on '04s. My instructions state "All X3's"
Old 04-15-2013, 08:57 PM
sixspeedz's Avatar
Will order the cable and give it a go, thanks.
Old 04-20-2013, 06:47 AM
fhopper's Avatar
fhopper fhopper is offline
Mein Auto: '04 X3 3.0i
I put the BMW kit in my '04 and it cuts out after about an hour of play, (using an iPod). I am assuming a heat issue in the radio itself, it only cuts out using the AUX. When I have time this spring I intend to re-do the install. The Business radio sure is a piece! I wish I were not a stock freak but I cannot imagine an after market radio looking anything but horrific in the dash.
Old 04-21-2013, 12:31 AM
Can't help you with the cutting off problem, but I totally agree about aftermarket radios looking bad in the dash. I was looking through Crutchfield, thinking about installing one and came across the adapter:
http://www.crutchfield.com.edgesuite...BW2337B-o.jpeg
NOPE! I'll stick with the Business radio.
Old 06-26-2013, 04:20 PM
LYTSOUT LYTSOUT is offline
Mein Auto: E83
sorry, but i'm a bit confused. what exactly does this install? is it a 3mm headphone "female" receptacle mounted into the side of the glovebox? or does it leave a length of "male" cable dangling in the glovebox to which you'd plug in the device? if it leaves some "male" cable, is it only 3mm or can it be an apple/ipod/iphone connector? i want to be able to charge my iphone while playing it...i don't mind controlling the music from the iphone so i don't really care much about integrating the menu/controls into the screen on the dash. if it does, that's nice, but not necessary.
i've already researched this subject and this is what i came up with prior to finding this thread (see link below). i'm not sure the difference between what you guys are talking about above vs this below except that this specifically says "ipod" at the top and the picture clearly shows an apple connector in the pic.
http://www.bmw-planet.com/lib/Gen2%2...%20&%20E86.pdf
lastly, i don't have a CD changer, and i don't think i have DSP. does it matter for either of these installations? thanks!
-2004 BMW E83 X3
-2004 Porsche 911 Turbo Cabriolet
-2007 Jag XK (wife's)
-1999 Jeep Wrangler
(all black)
Old 06-26-2013, 04:57 PM
fhopper's Avatar
Yes.
You may mount it elsewhere if you like but yes that is all it is. Seems like there was something about a resistor; I bought the BMW kit.
Old 06-26-2013, 05:30 PM
sixspeedz's Avatar
'04 BMW X3 AUX wire
Just did the install last weekend. Easy, and I chose the ashtray in front console.
Old 06-26-2013, 06:14 PM
fhopper's Avatar
Nice.
Old 06-26-2013, 06:28 PM
Originally Posted by LYTSOUT View Post
.... sorry, but i'm a bit confused.
As already mentioned by fhopper and sixspeedz, the basic $35 BMW aux-in kit is just a proprietary cable that plugs into the radio to update it to aux capability.
(Really neat installation sixspeedz - without using that metal plate that comes with the kit.)
You supply your own 3.5 mm connecting cable for your music player.
This low cost route does not provide charging capability.
There is a more expensive BMW option, and aftermarket ones, that do provide charging and additional audio program control, but not everyone is overly impressed with them.
I'm confused as to why simultaneous play back and charging is required by many people.
Isn't the point of these rechargeable devices that you charge them as needed when not in use?
It's not as though using the MP3 capability depletes the battery in a hurry.
What's wrong with a separate USB adapter for one of the 12V cigarette lighter sockets?
Eliminates the possibility of interference of the audio signal from the power supply which has always been a factor in automobiles.
Old 06-27-2013, 04:10 AM
sixspeedz's Avatar
'04 BMW X3 AUX wire
Thanks! I DID use the plate, but flipped it over, painted it black, and crazy glued it to the tray.
Then I ordered a $5 cable that brings power and audio from both jacks in my ashtray to a single iPhone connector.
To address to cables on my gear shifter, I ordered a $3 clip to hold the phone up on the heater vent... Should work just fine.
Old 06-27-2013, 01:20 PM
Frenchie31 Frenchie31 is offline
Mein Auto: 2005 BMW X3 3.0
'04 BMW X3 AUX wire
Where did you get the kit from and what is it called if I may ask I am very interested thanks
Old 06-27-2013, 01:52 PM
sixspeedz's Avatar
iPod Interface Kit - P/N 65 11 0 409 343
MODEL
X3 (E83): Select Vehicle Production 09/03 On*
X5 (E53): Select Vehicle Production 10/00 On**
Z4 (E85): Select Vehicle Production 10/02 On***
Z4 Coupe (E86): Select Vehicle Production 05/06 On****
5-Series (E39): Select Vehicle Production 9/00 8/03**
Old 06-28-2013, 05:00 PM
'04 BMW X3 AUX wire
Thank you now I'm bout to go and find it
Old 06-28-2013, 05:08 PM
Mein Auto: E83
would you mind sending a pic of the finished product with all the cables, mount, and iphone together? has anyone seen the proprietary apple connector installed thru the ashtray like that? that's a good spot for it
as for why we want charging capability: the X3 is our 3rd car and the one we use for road trips, so the iphone will be plugged into it for hours and therefore get depleted relatively quickly, esp when using navigation and other apps.
-2004 BMW E83 X3
-1999 Jeep Wrangler
(all black)
Old 06-28-2013, 05:42 PM
sixspeedz's Avatar
sure, will snap a pic tomorrow with something other than my iphone!
Old 06-29-2013, 08:51 AM
sixspeedz's Avatar
'04 BMW X3 AUX wire
Well, maybe not lol. Here is a pick with no phone in the holder..
Old 06-29-2013, 09:35 AM
'04 BMW X3 AUX wire
Old 08-11-2014, 06:22 PM
Tarynb2 Tarynb2 is offline
Mein Auto: 04 X3 3.0
Attachment 383755
I was wondering what directions you used to place the aux connection in the ash tray? That's where I'd like to put it and also if it was successful and worked properly??
Old 08-16-2014, 08:20 AM
sixspeedz's Avatar
there were no specific directions for putting it here, i just ran it through once i had the dash opened following the other directions.
works great.
Old 12-08-2014, 06:50 PM
UFRIENDLY's Avatar
UFRIENDLY UFRIENDLY is offline
Mein Auto: 2005 x3
AUX randomly switches back to radio, why??
The dealer put this in the glove compartment a couple of years ago. Never really worked as advertised. As I'm listening to iphone 5 music or gps it all of a sudden the switches to radio. Doesn't seem to happen with bumps loudness , I even changed cable
Apparently you can't use Bluetooth for music???
