E46 (1999 - 2006)
Old 04-16-2013, 05:48 PM
stanguss66 stanguss66 is offline
Mein Auto: 325i
P0014 After aligning double vanos
Hey guys,
I have a 02 325i that I just changed out the vanos for one from Dr. Vanos. In the process I broke some two of the hex bolts on the exhaust cam sprocket. I replaced that and followed the procedure to time the cams. I used the vanos timing tool to align the plungers and the car started like a charm. It restored power and the "service engine light" was gone. After 55 miles driven, the light came back on with P0014 exhaust over-advanced. The car now stalls every now and then. Oil pressure is running at .8 BAR at Idle at normal temp, and increases up to 4 BAR at around 3000 RPM. I see that some people corrected this issue with the cam sensor but I checked voltage and read 4.99v and it fluctuated as metal was passed through the magnet using a wrench. I figure the sensors are good and oil pressure is good. Any Ideas what is causing this?
Old 04-16-2013, 08:30 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Please clarify which bolts you broke. The VANOS on the M54 is replaced independent of any cam timing.
Old 05-03-2013, 02:29 PM
Mein Auto: 325i
brocken bolts
sorry guys, I've been out of town for the last 2 weeks. Let me clarify my last post of the broken bolts. When I removed the vanos, I also took off the exhaust camshaft bc there was a stripped bolt on the No. 1 cylinder cap. I tapped it and re installed the camshaft, along with a new cam sprocket because I stripped the inner threads on the original sprocket that hold the 3 hex studs.
I followed the TIS procedure to install the chain around the exhaust sprocket, careful to align the arrow to the top of the cylinder head. The only thing I did not use was the chain alignment tool for the secondary chain. Instead, I counted a total of 17 pins between the end of the cutouts of the sprockets, as described by CHILTON.
I finished the procedure by aligning the plungers with the vanos alignemtn tool bolted onto the head. Once that was done, I rotated the engine twice and landed No. 1 cylinder at TDC. The pin was in the flywheel and the cam blocks were flush on the head with just a little raised on the intake side.
THe car ran perfect for about 55 miles, now I have the P0014 and P0015 for over advanced and over-retarded exhaust camshaft timing.
