Old 04-17-2013, 07:42 AM
light1 light1 is offline
Mein Auto: 2011 335xi, 2009 750LI
Sound and idrive update for bluetooth
Hi,
I have an 09 F01.
Couple of questions: I noticed that the iPod adapter uses analog signal, and the sound isn't as good as CD or even radio. Do you guys recommend simply using a USB stick or an android that uses the USB connection and by-passes the Auxiliary?
My second question has to do with the Bluetooth, currently I can't play music of my devices using Bluetooth, but Google maps for example sends sounds to the car using the "call feature", whenever new directions are sent, it says new call and then it ends the call. On my 2011 e92, the Bluetooth is able to play Audio from wireless devices. Can I update my system to accept Audio via Bluetooth?
Old 04-17-2013, 08:46 AM
Kar Don Kar Don is offline
Mein Auto: '14 & '15 i3, now '16 i3
yes please search. You need a Combox to stream bluetooth audio. Cost is around $600
2008 Mercedes-Benz CLS550 Iridium Silver/Black Leather -- P2/321/881 (leasetraded 1/10)
2002 BMW 325i --Topaz Blue/Natural Brown Leather --SP/PP/HK/CWP/Bi-xenon (Sold 9/06)
Old 04-17-2013, 10:42 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
Try bimmertech.
http://www.bimmer-tech.net/shop/bmw-...a-pnp-retrofit
Old 04-17-2013, 03:06 PM
Thanks, will a combox from a 2012 or 2013 work with an 09 if I find one used? Of course programming will be required.
