Water pump replacement 01 x5 4.4i - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 04-18-2013, 05:50 AM
bobsx5 bobsx5 is offline
Mein Auto: 2001 X5 4.4
I am a moderately efficient DIY'er (on a scale of 1-10 I would be a 41/2). My '01 x5 E53 needs to have the water pump replaced. Is this a project I could do?
Old 04-18-2013, 07:53 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Yes. Definitely. I think the toughest part is opening the hood...
nah, maybe getting that fan to break free. Some videos make it sound easy, I let it soak in penetrating oil overnight before prying a flat tip screwdriver in between the screws on the pulley and cranking down on the 32mm (i think) wrench.
Be sure to use 50/50 mix distilled water/BMW coolant.
Basically, read and re-read this to see if you can tackle it.
Old 04-18-2013, 09:37 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Yes removing the fan shroud is rather tricky, but if you buy the tool on eBay (not much money really, it'll be easier), also remember that fan clutch nut is reverse thread, clockwise to loosen.
Then the next tricky one is sliding the old WP and new WP, not much room in there, just a lot of patient.
I'd recommend highly to create a very simple "jig", out of 3 long 10mm scres from Home-dpot, so the new WP can only slide perpindicular to the engine block, else you may pinch the o-ring of those two pipes and have leak. Well I did twice until I create the jigs.
I can take picture of the screws and tools later when I got home if you want.
Old 04-18-2013, 10:25 AM
Thank you both.....next weeks DIY. Wish me luck.
Old 04-18-2013, 10:32 AM
ECSTuning's Avatar
Instructor of the Stig™
The diy boramkiv linked is one of the better ones, it really lays it out for you.
Most of the time when you replace the water pump you'll also want to replace the pulley as well. We've had tons of positive feed back on the Uro aluminum pulley (LINK).
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Old 05-14-2013, 10:00 PM
BmanRRT BmanRRT is offline
Mein Auto: 2000 x5 4.4L
How did it work out? Looks like ill be doing it too
Old 05-15-2013, 06:19 AM
waterpump
Haven't done it yet. Life keeps getting in the way.
Old 04-04-2014, 10:47 AM
Slowhand Slowhand is offline
Mein Auto: 2003 BMW X5 4.4i
I had mine done yesterday, by a certified Master Mechanic. It took 4 1/2 hours and I spent $304.00 on labor, $276.00 for the parts and 25.00 for the orange coolant. After watching him do the deed, it was well worth the money. I read through the DIY and it's great, if you have the time and mechanical ability.
