Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 04-18-2013, 07:32 AM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
CPS question S52
Hi all.
I recently picked up a 1998 M3/4/5 and while attending to some much needed motor work I noticed that the Crank shaft position sensor seems to be non existant? am I nuts or is this normal? All my other BMWs with M50/52/52tu all had one, this has the spot for one, and its empty. However I dont see a plug for it, and the car runs..
Old 04-19-2013, 06:01 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
The CPS on the s52 (OBD2)is located on the block by the flywheel.
m
Old 04-19-2013, 08:50 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
That would be odd, huh? The DME needs the CPS signal to run. As 7pilot stated, it is on the block near the flywheel, which is towards the rear of the engine, where it interacts with the transmission. The M50 had it up front where it was easier to get to. Now it's in a really cramped place.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-26-2013, 03:04 PM
Nline6's Avatar
Mein Auto: E36 M3
I see that lol, Hope it doesnt fail! Thanks for the input. I knew it had to be around...
