Old 04-18-2013, 12:04 PM
HansP HansP is offline
Mein Auto: E90
E90 Battery change from Lead Acid to AGM, induces door actuator fuse blown?
1 year ago, collision center mistakenly changed the battery from LeadAcid (default one equipped before I believe) to AGM for my E90.
I just realized that when I checked up in body shop yesterday, and they recommend me to update the system. Surely I will do.
But this recalls me the something that happened. One day later after changing the battery from LeadAcid to AGM, there was door acuator fuse blown. Collision center told me at that time, it does not relate with new battery, just aging made that happened.
How do you think? I am thinking it is related. I need logical explanation about it.
Old 04-18-2013, 06:47 PM
fun2drive's Avatar
BMWCCA 149159
Not it is not related at all.
Something else blew your fuse maybe a pwr wire touching gnd...
Old 04-18-2013, 08:26 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
door actuator fuse needs to be changed to 20amps instead of 15.
Old 04-18-2013, 10:34 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
That is never advised.
OP, the only thing that needs to be done when using AGM is to program the car so it knows the battery is AGM. Replace the fuse, see if this is an on-going issue or just a one-time thing.
Old 04-19-2013, 03:40 AM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
I believe there's a service bulletin that says to install a larger amp fuse. It's normally not a good idea, but BMW knows best.
Also, get the car recoded so it knows there's an AGM installed.
agm, battery
