Tire Pressure with New Non-Run-flats PSS - Bimmerfest - BMW Forums
Old 04-18-2013, 12:20 PM
rmnelson12 rmnelson12 is offline
Mein Auto: E93 09 6MT
Question Tire Pressure with New Non-Run-flats PSS
Just mounted and balanced some new Non Run Flat Michelin PSS to replace the stock Run Flats. The ride is great, I love em. But the tire pressure in the fronts are 45 and rears 48~.
NRFT or not, should the tire pressures still match does on the door frame and manual spec? OR do these tires require a different, higher tire pressure (PSI)?
Old 04-18-2013, 12:23 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Two answers 1.Yes the door sticker is what most recommend you use. 2. That being said the M3 which has get flats the door sticker is about 5-6psi lower IIRC.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 04-18-2013, 12:27 PM
Roger that, sounds good, I'll keep em at the door PSI levels MAX.
Old 04-18-2013, 12:45 PM
Speedwagon's Avatar
Speedwagon Speedwagon is offline
Mein Auto: 2012 328IX Sportwagon
Running the max tire psi from the door sticker will give you a rougher ride, but will perform better!
Old 04-18-2013, 02:49 PM
Joe in Dublin Joe in Dublin is offline
Mein Auto: 335ic
Im running m3 pressure. I ran a post about this awhile ago and got alot of info. But your door sticker is for run flats. They are different. You now have a m3 set up...
Old 04-18-2013, 02:53 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
Not a tire manufacturer mind you but, Run flats are much stiffer sidewalls. So, running a higher pressure on the "go flats" would better approximate the run flat behaivor. Like i say, just thinking outside the box. I switched to PSS about a montha go and running 37 on front and 43 on back per the door sill sticker. Not at max P but close.
I have sport package.
Old 04-18-2013, 02:54 PM
http://www.bimmerfest.com/forums/sho...d.php?t=684414
Whats the m3 tire pressures did you end up using for your e93?
Old 04-18-2013, 03:12 PM
Mein Auto: 335ic
My theory is... The run flats have a plastic ring in the side wall to prop up tire when its flat. They have u put alot of pressure in the rears to prevent that ring digging into to bottom of the tire due to higher negative camber on bmw rear tires
Old 04-18-2013, 03:32 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
45/48 is insane ... I'd lose my teeth. You'd be fine with 35/36 +/- 1 PSI
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 04-18-2013, 05:21 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
If you have the exact same size as the original tires, yes you should go with the door (BMW) recommended air pressure. RF and non-RF (size for size) do not have different air pressure requirements according to U.S. or E.U. tire load/inflation standards.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 04-18-2013, 05:28 PM
Mein Auto: 335ic
Then why does the m3 have different pressure settings. Same size tire...
Old 04-18-2013, 05:32 PM
pointandgo's Avatar
You're talking about front to back difference? There may be various reasons why BMW wants this such as to impart a certain amount of understeer in the car, or to accomodate axle weight differences, etc.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 04-18-2013, 05:46 PM
Mein Auto: 335ic
M3 36f 38r, 335i 36f 44r. Both 08 both cabs, same tire size just run flat vs go flat. U cant tell me the m3 is hundreds of pounds lighter than 335. Its because of the different tires. Over inflate rears on 335 to prevent run flats from destroying themselves.
Old 04-18-2013, 06:11 PM
pointandgo's Avatar
Joe, I can only recommend to not be fixated on the M3 pressures. Nothing to do with the 335i, and I'm not sure why you're trying to relate the two.
See my previous post...
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 04-18-2013, 06:50 PM
Mein Auto: 335ic
Actually the m3 and 335 are very simliar. Same weight same balance and now same tires.
Old 04-18-2013, 07:36 PM
Bill-SD's Avatar
Bill-SD Bill-SD is offline
Mein Auto: 2007 335i Coupe
I'm with you!
E92 335i - Monaco Blue/Saddle
F30 328i - Alpine While/Black|SportLine
Old 04-18-2013, 07:41 PM
im running 41 / 44, since highway driving in texas is usually around 90 to 100
Old 04-18-2013, 08:12 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
I need to get new tires and all I want to know is if it made that much of a difference with the non run-flats without suspension change out?
Old 04-18-2013, 08:20 PM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
Wow, in the parts of Texas I've driven (Dallas to San Antonio on I-35) and from Houston to Dallas (forget the interstate), and I-10 from Houston to SA, those speeds would put you in jail.
Old 04-18-2013, 08:24 PM
not when the speed limit is 85
Old 04-18-2013, 10:53 PM
thekurgan's Avatar
Bad Lieutenant
Different suspension setup. Stiffer dampers springs bushings alignment all contribute to handling differences. 38 psi in my M3 is nightmarish on public roadways.
Ilse
Bruna
BMWCCA #453648
Old 04-19-2013, 08:44 AM
Spagolli94 Spagolli94 is offline
Mein Auto: 2017 3401
I have the same tires and run what's suggested in the door jam. I have an E90 335i with sport pkg and it says 33/41. Seems like a weird pressure, but the car rides nice and handles well.
Old 04-19-2013, 10:54 AM
Mark K Mark K is offline
Mein Auto: '17 GTI '16 981 CS
If you have Michelin PSS, you better watch out and test your tire pressure after high speed run immediately. I've gotten 10 psi pressure increase from cold to hot after 30 min on a racetrack. That would bring your tires to 51 and 54 psi. Problem? Max allowed on OEM Potenzas was 60 psi, but for PSS max is 50 psi. I would disregard door recommendations for high speed inflation if you are running non run flats, more specifically Michelin PSS.
I run PSS at 36 front and 39 psi rear.
_
2017 Golf GTI |Silver over tartan cloth| MT| Base S, no options. Oh, wait! ... It does have a spare tire!
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI [CONFISCATED]
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
Old 04-19-2013, 11:18 AM
I found the M3 rates much better all round than the 335is door sticker with no adverse tire wear.
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 04-19-2013, 01:25 PM
SpartanGA SpartanGA is offline
Mein Auto: 2007 550i, 2011 335i Vert
Which is what? And is this 18 or 19 wheels?
Thx
Jim
2007 550i Sport - White - Tan
