Old 04-18-2013, 01:25 PM
2secondslater 2secondslater is offline
Mein Auto: e60 523i, e38 740i
740i check collant level?
Hi everyone! Im new owner of 1995 740i and i love it. This car needs a bit of love, its my weekends car and i want to keep it the way she came from factory. I get the above message, but its all seems to be ok. I was taking to my father which is in different country and he said something about the air in collant system or collant level sensor. What do you think? Anyone can point me in right direction and tell me how to get it fixed. Another problem is that wipers stopped working, but the windscreen washer jets are working. Also windscreen water tank has some kind of sensor with cable and is rusted and broken, needs replecment. Whats the correct name? for it?
Thanks for the help
Old 04-18-2013, 02:30 PM
Moveitsmike Moveitsmike is offline
Mein Auto: 97' BMW 740il, 06' 330i
take a picture?? if the floater in the radiator is not floating its not level, top it off with some water...
Old 04-18-2013, 02:51 PM
First740il First740il is offline
Mein Auto: 740il
DO NOT PUT WATER IN YOUR CAR. Only put a mix in it. Not just radiator fluid and not just water has to mid or things can get worse fast.
Sent from my DROID RAZR HD using Bimmer App
Old 04-18-2013, 03:15 PM
Ok i will take picture tomorrow, but it is floating, if i push it down it comes back right away. Any other suggestions, what do you think about what i said? Thanks for help
Old 04-18-2013, 05:40 PM
Mein Auto: 740il
I'd its doing what you say its full on fluid.
Old 04-19-2013, 05:45 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
See also:
- Expansion tank floating mechanical coolant level sensor height (1) (2)
Old 04-19-2013, 02:57 PM
you can top it off with water... with the coolant. that is a mix.. i never said just put only water in the cooling system...
Old 04-20-2013, 10:25 AM
Mein Auto: 740il
Don't top off with water. How much could toping of be. That is a bad frase to use In The car world if you ask me.
HTML code is Off
