Old 04-18-2013, 09:22 PM
HerbP HerbP is offline
Alternator/ Dynamic Drive Question
My Dynamic Drive problem has been driving me crazy for a while now. I did a lot of diagnostics this week, & things are starting to point to the alternator. I am getting over voltage from the alternator, causing problems with over voltage on circuit 30, that feeds the Dynamic Drive.
When the voltage spikes, it causes a problem with the Dynamic Drive system. I also spotted some type of code from the alternator, but it deleted itself when I ran a quick test. Running a test on the DME, my voltage started spiking, & the engine started surging. This was when the engine had very little voltage draw, with almost all creature comforts & lights off. The warning light goes off at random times, but usually after the car has been driven for 20 minutes or more. I guess this would have time to charge the battery, & cause the voltage regulator to not control properly. I saw voltage spiking up to 16 volts. I have an over charging issue, verses a normal loss of charging output. My battery is around 6 months old, & is checking good. I hate to spend a 120.00 on a voltage regulator, when I can buy a New Valeo alternator for 299.00, shipped to my door. Does anyone have any thoughts that might help me confirm my suspicions? I am using DIS & INPA to do my diagnostics, along with a VOM.
Thanks for any thoughts!
Herb
Old 04-19-2013, 02:53 AM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
Herb
They don't cost $120......
Get it right now for $69.95 on Ebay
http://www.ebay.com/itm/BMW-X5-545-6...041e66&vxp=mtr
Search around....when I bought mine it was $35 but I can't remember the website.
Here is Exactly which one you need
[/QUOTE]
Old 04-19-2013, 05:35 PM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645 / 14 435I
Do you have to take the alternator off to change this out?
Old 04-19-2013, 08:27 PM
It can be done, but it will be fairly tight. I have not done this yet, but I have read threads stating it can be done. I am still debating whether I am going to buy a new alternator, or buy the voltage regulator. Based on all of my testing, I think I could get by with just a regulator. My problem is if the regulator does not fix the problem, I have wasted 100.00. Your car could have a different problem, resulting in a different repair. The alternator can be removed & installed in around 1 to 1.5 hours once you have removed it before.
Old 04-19-2013, 09:25 PM
D Woolley
I've been told that it could be that or the alternator. Do you have a DIY on how to change out the alternator? It looks real tight.
Old 04-21-2013, 01:49 PM
Here is a thread that I found today that helps confirm that my voltage regulator is bad. It is amazing how many dealers can not diagnose this problem. Below is a very good thread to read.
http://www.bimmerfest.com/forums/sho...d.php?t=316911
Old 04-28-2013, 09:04 PM
I finally got around to my changing my voltage regulator out today. It took around 1.5 hours to complete the task. The alternator is putting out a steady 14.4 volts. I have not heard the engine idle this steady, in quite some time. It will probably take a few days of driving, to see if my Dynamic Drive errors go away. I will make a post in a few days, to update everyone.
I am hoping for the best!
Old 04-29-2013, 07:33 AM
D Woolley
Herb,Was it pretty simple to pull the altenator?
Old 04-29-2013, 06:38 PM
You need tor remove the cooling fan 1st. This is done by removing the top cover for the radiator. This is 10 bolts that have torx heads. Then remove the drive belt. The alternator has 2 bolts that will need to be removed. Unplug the wire with the plug, & remove the hot wire to the battery. Then you have to work the alternator out of the bracket. The hard part is getting the alternator seated back in the bracket properly. After that is fairly easy. Make sure to remove the ground wire from the battery per TIS.
Good Luck
Old 05-06-2013, 07:34 PM
After 7 days of driving, my Dynamic Drive error is finally gone. I hope this post might help others with the same symptoms!
Old 05-06-2013, 07:36 PM
D Woolley
I took the plunge and had a alternator put in on Friday, no dynamic drive issues so far.
Old 05-06-2013, 08:38 PM
I hope it works out for you. Who would have ever thought the 2 would have been related?
Old 05-07-2013, 09:05 AM
D Woolley
I never would have believed it.... But working for now.
Old 06-27-2013, 08:05 AM
numoo numoo is offline
Mein Auto: 645 CI Conv
"HerbP
You need tor remove the cooling fan 1st. This is done by removing the top cover for the radiator. This is 10 bolts that have torx heads. Then remove the drive belt. The alternator has 2 bolts that will need to be removed. Unplug the wire with the plug, & remove the hot wire to the battery. Then you have to work the alternator out of the bracket. The hard part is getting the alternator seated back in the bracket properly. After that is fairly easy. Make sure to remove the ground wire from the battery per TIS."
Did you have to remove all the hoses in front of the Altenator? I have a 2004 645. Thanks
Old 06-27-2013, 11:43 AM
You will not have to remove any coolant hoses. The recirculation pipe/line on top of the cooling fan will need to be worked around, or removed from the expansion tank. This line is usually quite brittle, so be carful while working with it.
Old 06-27-2013, 11:45 AM
Thanks! HerbP.
Old 06-29-2013, 07:57 AM
Do I need the PIN when releasing the tension pulley ? Tool 11 3 340. Also any one know what size the Torx is for this pulley , 45 was to small.
http://www.dingocroft.co.uk/acatalog/Engine_Tools2.html
http://bmw.workshop-manuals.com/6_Se...dex.php?id=369
Old 06-29-2013, 05:52 PM
The pin is not needed to remove the alternator belt. The pin is used for installation purposes. Do not remove the pin, until getting ready to install the belt. I think the torx head is a 50.
Good Luck!
Old 06-30-2013, 08:12 AM
Anybody got advice on how to get the alternator of the bracket? This sucker just does not want to wiggle off! Belt off, bolts off...alternator not cooperating. There goes an 1.5 hrs this morning.
Old 07-01-2013, 03:19 PM
The alternator is a very tight fit. If you remove the nut on the drivers side motor mount, you can raise the engine to gain more room. You can use a floor jack & a block of wood to raise the motor around 2". Pay very close attention to not keep jacking, when the motor hits the firewall. You should be able to use a pry bar to work it out of the bracket.
Good Luck!
Old 07-01-2013, 08:36 PM
Thanks HerbP.
Funny that the TIS mentions nothing about that. It makes it sound as if it would slide forward once the deflector wheel on the alternator was taken off.
Old 07-02-2013, 12:11 PM
Thanks HerbP.
You learn the things from the school of hard knocks!
Good Luck!
Old 07-02-2013, 12:20 PM
Kevin Bowen Kevin Bowen is offline
Mein Auto: 2001 E39 & 2005 645 ci
Your Alternator Problem
It's your voltage regulator. You can get one on ebay for $55. I fixed mine about 3 weeks ago. Go to BimmerForums. I did a complete write-up with pictures. Just search my name "Kevin Bowen" and you will find it.
Old 07-11-2013, 12:09 AM
Thumbs up Alt Test result from PepBoys
Thanks very much to both Herb and Kevin.
So I got this result with the the new regulator (see thumb nail). Did either of you get your alternators tested? I got mine tested at PepBoys and Orileys, the results were the same.
Anyone know what the "Lamp on voltage" means? (Read on another form that these Tests are not accurate and have errors also) I'm tempted to put this back on the car, as the higher voltage B+ came down from 15.15, and ripple dropped from 0.77. The Failed test did not change from old to new VR.
Drove from Baltimore to Houston and the car did not die on me with original VR. I did have a spanking new battery placed before I did that though. Just kept getting one elct error after another, which would go away and come back on its own, like Herb, Kevin and some of the others on this forum.
Any last advice gentlemen?
Thank you all.
Name:	Alt test photo.JPG
Old 07-11-2013, 09:34 AM
Did you replace the regulator ?
