Old 04-30-2013, 10:23 AM
BmwFlooner's Avatar
BmwFlooner BmwFlooner is offline
Mein Auto: 13' 335i M-Sport 6MT
Originally Posted by SergioK View Post
The clutch pedal and clutch disc are controlled via a hydraulic system. It's a closed system thus speed of clutch engagement can vary depending on how fast you depress the clutch pedal. The CDV aims to slow down the actual engagement of the clutch if you simply 'pop' your foot off the clutch pedal.
That was my understanding, and that it's something that doesn't interfere with normal shifting.
Old 04-30-2013, 11:41 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
The clutch pedal and pressure plate are controlled via a hydraulic system. ... The CDV aims to slow down the actual engagement of the clutch if you simply 'pop' your foot off the clutch pedal.
Fixed. The friction disc is splined to the transmission input shaft; the pedal controls the pressure plate bolted to the engine flywheel.
Partially incorrect. The design intent is to protect the driveline from "dumping" or "popping" the clutch as described. However it most certainly does interfere with normal shifting. The restriction is asymmetric--the restriction is greater when engaging than disengaging the clutch--and the orifice in the valve is so small (~10% of the unrestricted cross-sectional area) that the system is not operating in the linear range. That is, the movement rate of the clutch linkage is not in constant proportion to the movement rate of your foot; it varies with the speed of release.
The net result is that the CDV makes it exceedingly difficult to achieve consistent, smooth clutch engagement, because the precision with which the clutch fork responds to pedal travel is significantly reduced. The non-linearity makes it hard to compensate for the minute added delay because the delay is not constant.
(The above applies to the E9x valving. The F30 is no doubt similar if it has a CDV, or "lock valve" as it is officially called.)
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 04-30-2013, 11:56 AM
Jamesonsviggen Jamesonsviggen is offline
Mein Auto: '98 M E36/7:'06 Saab 9-5
The net result it that the CDV makes it exceedingly difficult to achieve consistent, smooth clutch engagement, because the precision with which the clutch fork responds to pedal travel is significantly reduced. The nonlinearity makes it hard to compensate for the minute added delay because the delay is not constant.
(The above applies to the E9x valving. The F30 is no doubt similar if it has a CDV, or "lock valve" as it s officially called.)
Thanks, saved me the typing lol.
E36/7: Dinan/RMS stage 2+ blower@11-16lbs of BOOST! 18" BBS LM's, too much more to list
F30: 6mt, SOLD
'06 Saab 9-5 wagon 5mt LSD, clipped turbo, 19psi, 400ft lbs of tq
Old 04-30-2013, 12:20 PM
BmwFlooner's Avatar
Thanks for the writeup
That sounds pretty undesirable. So the 99% of time you're shifting suffers to protect you against the 1% of the time you bork a shift?
I assume removing it has implications for warranty claims against the clutch.
