Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 04-19-2013, 10:01 AM
bmwporschemike bmwporschemike is offline
Mein Auto: bmw328ix
spare tire for run flat M3
The M3 I'm about to take delivery of (an '08 with run flats), needs new tires. I'd like to replace them with non run flats.
I recall reading about a company who sells a "donut" spare tire for bmws - almost all of which have 5 x 120 pattern bolt pattern. I checked on this for an F10 (new gen) 5 series. I think they recommended an 18" rim with a thin spare tire to match the rolling diameter of the OEM rims/tires.
Anyone recall the name of this supplier? Thanks
Old 04-19-2013, 11:01 AM
650 Ryder's Avatar
650 Ryder 650 Ryder is offline
Mein Auto: Dinan///M3 - Countryman S
M3's don't come with runflats so if this car has a set on it I would really checkout the car. I'm guessing you worked through the electrical issues from your other post. If you are daily driving the car I would just get a mobility kit. For long hauls a spare might be a good idea. Do a quick google search and you should find the spare you're looking for...........Phil
2011.5 Dinan ///M3:
SSII DCT
Comp, Conv, Prem 2 Pkg
Heated Seats
Enhnd Prem Sound
BMW Edition Grills / Gills
BMW M Perf. Steering Wheel
BMW C/F Perf. Spoiler
BMW Pedals
Dinan Exhaust
Dinan Mid Racing Exhaust
Dinan Carbon Fiber Intake
Dinan Racing Middle Exhaust Software
Dinan DCT Tune
Dinan Pulley Kit
Dinan CH-R Wheels
Dinan Carbon Fiber Strut Tower Braces
IND M5 Scheme Mirror Caps
Arkym Front Lip
C/F Reflectors
Lux H8 V3
Brembo 365mm BBK
Swift Spec-R Springs
Old 04-19-2013, 04:58 PM
enigma's Avatar
enigma enigma is offline
Fight On!
Mein Auto: BMW M3, Z4 M Coupe
No M car comes with RFTs (thank God!) as far as I am aware. But the M-Mobility kit is standard, so the OP should already have it in the trunk?
BMW CCA Member #xx4477
2006 Z4 M Coupe (e86) 6MT
2013 M3 Coupe (e92) 6MT
Old 04-20-2013, 10:21 PM
1fastm3 1fastm3 is offline
Mein Auto: M3, 335xi, X5 4.8
I highly doubt the car has the original tires after five years. Most likely the previous owner cheaper out and stuck rfts on it.
Old 04-20-2013, 10:23 PM
http://www.m3post.com/forums/showthread.php?t=150955
Post 20 and after has your answer.
Old 04-20-2013, 10:43 PM
Mein Auto: bmw328ix
Re: M3 and "spare" tire
Here is a site that sells a "donut" spare for all bmw's without a spare. I did further research and found that indeed the M3 does not come with run flats nor a spare. So either you have "great" roadside service, a "patch" kit (sticky stuff plus a compressor) or you can buy a pre-assembled donut spare from these folks for under $300.
http://www.bimmerzone.com/product/BIM-SST-F10-KIT.html
Funny, years ago, any local service station or mechanic carried a "patch" kit - which consisted of a rubber plug, special glue and a sort of "pawl" tool. You pulled out the nail, etc., used the "pawl" to clean out the hole in the tire, then put the rubber plug (after putting on this special glue) into the hold. Cut the piece still sticking out past the tread - and off you went. Sometimes this patch would hold forever, other times it could start to leak - but usually with sufficient warning - to get you first to a tire place to have a permanent repair done. No places still offer this service. I think it's due to potential liability issues (such as a possible blow out if the patch "let loose" all of a sudden).
Old 04-20-2013, 11:33 PM
highyo highyo is offline
Mein Auto: X5 50i, M3
in NYC you can get this done for 15 box. it's out there.
2016 F15 X5 35i, Spacegrau, Canberra Beige/Black, Fineline wood trim, Cold Weather, Driver Assistance Plus (ACC), DHP, Luxury Seating, Premium Package, Harman Kardon
Old 05-02-2013, 11:21 AM
kurtv kurtv is offline
Mein Auto: 2006 BMW 330i
Spare tire for E90 series
Here is a discussion thread on spare tire kits for the E90. Should work for the M3 as well. I bought a kit from Tischer that included the tire, wheel and jack as offered on the 5 series.
http://www.bimmerfest.com/forums/sho...d.php?t=297373
Old 05-04-2013, 03:14 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
We have one for the E90+ M3, http://www.bimmerzone.com/BMW_Perfor...E90M3-KIT.html
This will give you the clearance needed for the brakes as well as the correct rolling diameter (in between the front and the rear)
Hope this helps.
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
