Old 04-19-2013, 02:18 PM
easymoney456 easymoney456 is offline
Mein Auto: 2007 750li
Low coolant and leak under the driver side.... Any idea?
07 750 li, drovr car for about a hour perfectly with no problem, I parked the car, came out a hour later to a thin liquid on the floor...
It looked like water but felt a little greasey, when I looked under the car I seen dripping from under the,driver seat.... When I start the car, it says low coolant....'
So is this a hose or water pump???
Sent from my myTouch_4G_Slide using Bimmer App
Old 04-19-2013, 02:47 PM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
This can be your Pandora box!!! Hopefully it the heat valve that goes to the heater coil. There a valve on the driver side just under the Power steering fluid Container. Check the hose. If not then it can be the rear seal on the cooling pipe!!! Big job tranny needs to come down.
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 04-19-2013, 02:50 PM
rideme2's Avatar
rideme2
But check the front of your motor the middle pulley is the water pump. Check for leaks on the hoses, and hoses on the radiator. Leaks can travel
Old 04-19-2013, 03:01 PM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
Hey easymoney456, I responded to your PM
Old 04-19-2013, 03:32 PM
So I can get lucky and it can be a hose?
Old 04-19-2013, 03:37 PM
rideme2's Avatar
rideme2
Yes check it.
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Also check the hose that connects to your lower radiator. There's a temperature sensor with an O ring that is known to go out and will seep out coolant.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 04-19-2013, 04:21 PM
Thank u, ima check all the above tomorrow....
If u come up with anything else please let me know.....
I just dont want to bring it to the shop and jerk me....
Old 04-19-2013, 04:26 PM
rideme2's Avatar
rideme2
If u are good on working on cars these job can be done in your driveway. Everything but the rear seal can be done on driveway.
Old 04-19-2013, 06:08 PM
Heater valve control....
They said thats the issue, it that covered under the cpo???
Old 04-19-2013, 06:18 PM
rideme2's Avatar
rideme2
It's up to the your dealer? Cause I know that CPO don't cover wearable parts.... Like brakes wiper blades hoses and what ever they Consider Wearable parts. When I had them look at my car for a lil leak on the lower hose of the radiator where there a sensor on it, the CPO cover the sensor but not the hose?!?! So I just replace the ring gasket of the sensor my self it was only 5cent. HOMEDEPOT:-)) this was 3year ago still no leak....
Old 04-19-2013, 11:26 PM
Another fact I forgot to mention.is that the antifreeze only leaks after I shut the car off.......
If I put antifreeze in.and drives, it feels normal the whole ride, once I turn the car off the antifreeze then leaks..........
The perdon that looked at the car earlier.arent too trusty, they didnt even do a pressure test...
Old 04-20-2013, 04:40 AM
rideme2's Avatar
rideme2
yea its sounds like the car builds pressure and looks for a weak spot to let lose. these cars have a problem with cooling. you can do a search on the forum and find so many of these cars with the same problem. my car i had to change everything that had to do with the cooling system. cause when i fix one problem i found another one. i drop my tranny myself at my brother shop to change the rear cooling seal. But good luck and check for leaks dry spots. if you are running the OEM antifreeze you will find WHITE dry spots. the OEM antifreeze is blue but when it drys out it becomes like this WHITE powder like stuff??
Old 04-20-2013, 05:49 AM
JUBMW JUBMW is offline
Mein Auto: 2003 BMW 745LI
I see you got with BMWOEM1 trust me you will be pleased letting him work on your car, matter of fact you will be wishing you knew of him sooner.
Old 04-20-2013, 12:53 PM
I was in a rush do I got it fixed at an indy spot in nj..... It was the heater control valve..... 185 for part and 100 for labor....... So 285 all together....
