Old 04-19-2013, 09:15 PM
sle39lvr sle39lvr is offline
Mein Auto: 08 E90
Error Code CF17
Scanned with BT Tool and I keep getting this error:
Gearbox Control Unit
CF17
Even after clearing it, it comes back after awhile. I searched around and could not see any explanations.
Old 04-22-2013, 02:50 PM
Mein Auto: 08 E90
Very odd that no one has an answer for this..Even Googling couldn't get me anything solid...
Old 06-11-2013, 01:13 PM
juice619 juice619 is offline
Mein Auto: bmw e90
Hey sle39lvr, did you ever figure out this code? i am also getting it along with cf14, they go away but come back right after.
Let me know
thanks
Old 06-11-2013, 10:21 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Soooo how exactly did you read those codes?
Old 06-11-2013, 10:38 PM
Mein Auto: 08 E90
I haven't had any luck yet.
I used the BT Tool to scan.
Old 06-12-2013, 04:13 AM
Give us detail - what was the whole text of what popped up?
Old 06-15-2013, 02:33 PM
Mein Auto: 08 E90
Exactly that:
Old 06-15-2013, 06:39 PM
Exactly that:
You drive a diesel? Wait...did they make 'em in 2007? Problem starting ever?
Just for fun, do this easy test:
Old 06-15-2013, 06:46 PM
Is this familiar?
Old 02-10-2014, 10:33 AM
lewclay lewclay is offline
Mein Auto: 2008 e92 328xi Coupe
Just got the Bav Tech tool and I am getting the same message. 2008 328xi
Did you ever find out anything about this error?
CF17
Old 02-11-2014, 08:28 AM
Mein Auto: 08 E90
Nothing yet. I asked several Indie shops. They all were confused about it, did more research, came back to me saying, do not worry about it since it;s very minor...
Old 02-11-2014, 09:47 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
did you do voltage test fool?
Old 02-11-2014, 09:50 AM
Mein Auto: 08 E90
Everything is fine with Voltage testing, even after a new battery.
Old 02-11-2014, 11:57 AM
Mein Auto: '06 AW 330xi
It's something to do with dsc "toque request"
Old 05-10-2015, 01:06 PM
clubs-fl clubs-fl is offline
Mein Auto: BMW 2008 328i
i have a faulty dsc pump, i don't know the fault is related to that.
i clear the code and it keeps on coming back. i don't know if should reset the transmission.
Old 09-01-2016, 03:34 PM
Irvin Ramirez Irvin Ramirez is offline
Mein Auto: 08 BMW 328i e92
Im having a similar issue in my 328i, CF17 is the only code showing in the scan. Does anyone else car stop and have trouble starting again? At first I thought it was the battery but changed it out and still had the same issue, the car would shut off while driving.
Old 09-04-2016, 06:05 PM
For the CF17 code, needed to replace the Positioning motor. This is the motor that controls the Xdrive.
Hope that helps!
