E34 (1989 - 1995)
Old 04-20-2013, 07:32 AM
HipMusic Man HipMusic Man is offline
Mein Auto: '89 535i
Control arm
Have an 89 535i and the control arm wont tighten. the bearing just turns. Whats the easiest way to get it to the recommended torque?
Sent from my SGH-T989 using Bimmer App
Old 04-20-2013, 05:27 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Put a wrench on the other end so the bolt doesn't spin
Problem is, we have no idea which bolt on which control arm you are talking about...
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 04-20-2013, 05:50 PM
Mein Auto: '89 535i
lower control arm. The bolt faces up and the control arm doesnt have anything to keep the ball joint from turning like the swaybar linkages do. Ill try putting a jack under it. Ive been told to try that
Old 04-20-2013, 05:59 PM
Larrick Larrick is offline
Mein Auto: 1994 525it
I've done the upper and lower control arms on a 1994 525i and had to use a "pickle fork" and a 3 lb. sledge hammer to get the ball joint out..
The ball joint is wedged in and difficult to remove.
If the front ends are the same, I would say that you ball joint is loose and you must find a way to keep it from
spinning. Perhaps a vice grip or pipe wrench.
I also used blaster to loosen the nuts.
Old 04-20-2013, 06:36 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
.... Ill try putting a jack under it. Ive been told to try that
This ^. I've seen this technique work. Just use a peice of 2x4 between the jack and ball joint.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 04-24-2013, 11:49 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
the arm isnt seated properly. It needs to be pressed in (not like a bearing is pressed in, i mean pushed into the slot), the same thing that makes them so hard to remove. I would c-clamp it in and then it should be "seated" enough to stop spinning.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 04-24-2013, 03:48 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
yep done this yesterday, and about to go and finish other side of the car after checking up here if you still have the strut bolted to the carrier bracket, a jack underneath will work. if you are meaning the front arms, you need to remove the sturt so the jack trick won't work, you need to use a C clamp or vise grips
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 04-24-2013, 06:16 PM
I must have misread the thread and thought that you could not get the ball joint loose. I used a pickle fork for that.
I did learn a trick for "pressing" the ball joint in.
Use a 17 inch channel lock. They are big and will open enough to get on top and bottom.
Use a clamp on the ends of the channel lock handles to squeeze the tapered ball join into place.
It is important to weight the vehicle properly when you tighten on the font end.
More important for the upper arms I believe.
You can buy 80 lb. bags of concrete at Home Depot and just return them after you are done.
