Old 04-20-2013, 09:39 AM
10Go 10Go is offline
Welcomed to the 'Fest
Mein Auto: E65 745i
Front Brake Sensor
Does someone have a picture of how your FBS should look installed when doing a front brake DIY? its "L" shaped and I thought the wire would follow that way over the caliper. Well, it broke. Does it go in the other way??
Regards,
Ten
745I
Slate Green Metallic___
Old 04-20-2013, 12:42 PM
1bad540's Avatar
1bad540 1bad540 is offline
I dont understand your question?? put a new sensor in and be done.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 04-20-2013, 12:56 PM
Mein Auto: E65 745i
It broke when I tried. When the sensor was placed on the pad connected to the piston, it broke. Im aware that it could only go on one of two ways. I'm asking to see a picture, not a sarcastic answer. I wouldn't bother asking if I knew. The sensor itself has a cable running from the long part of it (L) shape. The part where the cable/cord is coming out runs in which direction? Towards left or the right? I ran mine with the cable to the right threading the wire through the caliper.
When i tried to put the sensor in place in the pad and snap it into the piston, it broke. I went onto YouTube and tried to look around for a video but nobody had a good shot of the sensor. Just a before and after. I know your thinking "Why didn't you follow what you saw when you took it apart?". It was my first time and in between reading, trying not to break anything and looking for the right tools, I wasn't paying attention. **Take note DIYers**
Any non sarcastic advice would be appreciated.
Regards,
Ten
745I
Old 04-20-2013, 04:15 PM
Titleist Titleist is offline
Mein Auto: 2008 750i
if it is an aftermarket sensor the cable maybe a little shorter than the original. I had one installed...followed a similar route as the old one with a small detour around the upper guide clamp for the sensor...works fine
Old 04-22-2013, 06:18 AM
Davidf Davidf is offline
Mein Auto: various BMW's
Front or back, the sensor wire points toward the center of the car.
Old 04-22-2013, 06:35 AM
There are 2 guide holes or clamps for the FRONT brake sensor to follow. The one just above the caliper should be used but the upper needs some modification (I used a twist tie) but only if the sensor is not OEM as the cable is slightly shorter. This has been installed for over 6 months when I switched to ceramic pads and everything works great.
Old 04-22-2013, 06:20 PM
Mein Auto: E65 745i
Gentlemen,
Thanks for your advice. The problem has been solved. I told the part back to the dealer and explained what happened. Long story short, I was given the wrong part. Lesson learned, although he/she maybe the parts tech kindly ask them to double check.
Regards,
Ten
745I
