E30 (1982 - 1993)
Old 04-21-2013, 04:13 PM
claysones claysones is offline
Mein Auto: e30 325is
Steering pull problem.
I bought my first e30 about a month ago and love it. Im working through a few bugs to make it 100% perfect. The car was lowered before i bought it with Bilstein shocks and i believe H&R lowering springs, but i might not be correct on the spring brand. The car runs straight and true until you take a turn that requires more than one revolution of the steering wheel, then the car will pull that way until you make a turn in the opposite direction with the same steering rotation. Any ideas on what is causing this and what i can do to fix it?
Old 04-21-2013, 06:48 PM
downhiller's Avatar
livin large
bad tie rods, steering rack sticking due to bad/old fluid, bad ball joints, sticking calipers, could also be signs of a wheel bearing starting to go bad
Old 04-21-2013, 07:11 PM
I just bought the car and before i bought it I had the local BMW dealership and a certified shop do thorough inspections on the car and they did not say anything about that. Do you think it has anything to do with the shocks and springs?
Old 04-21-2013, 10:18 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
when, other than in a car park, are you turning the wheel more than one revolution? i rarely more than quarter turn the wheel
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 04-22-2013, 04:50 PM
Never, but if i pull out of a tight space and then get on the road the car will pull
Old 04-22-2013, 07:19 PM
downhiller's Avatar
livin large
its not the suspension, if it was it would be more consistent. you may be having a problem with your rack and pinion
Old 04-22-2013, 07:24 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
How much is the car lowered? Sticking rack sounds right. I havent heard of these cars are any cars really losing that much caster angle that the wheels wont recenter themselves.
Old 04-22-2013, 07:29 PM
downhiller's Avatar
livin large
really?
Old 04-22-2013, 10:07 PM
First time's Avatar
If you noticed I wrote caster not camber.
Old 04-23-2013, 07:34 AM
its not lowered much. Maybe an inch to an inch. The tires fit pretty well in the wheel wells but they dont rub at any steering angle. Do you guys think it could just be power steering fluid?
Old 04-23-2013, 10:28 AM
First time's Avatar
Worth a check. Maybe air in system?
Old 04-23-2013, 04:58 PM
downhiller's Avatar
livin large
but excessive camber will throw off caster. excessive as in that vehicle.
Old 04-24-2013, 07:22 AM
The camber hasnt been touched i dont think
Old 04-24-2013, 04:39 PM
downhiller's Avatar
livin large
if its been dropped the camber decreased. its how the suspension is designed. if you raise the car the camber increases if you lower the car it decreases.
and a lil thing i found on how camber and caster can effect each other
Front end alignment
When a vehicle's front suspension is aligned, caster is adjusted to achieve the self-centering action of steering, which affects the vehicle's straight-line stability. Improper caster settings will cause the driver to move the steering wheel both into and out of each turn, making it difficult to maintain a straight line[vague].
[edit]Positive caster angle
The pivot points of the steering are angled such that a line drawn through them intersects the road surface slightly ahead of the contact point of the wheel. The purpose of this is to provide a degree of self-centering for the steering - the wheel casters around so as to trail behind the axis of steering. This makes a car easier to drive and improves its directional stability (reducing its tendency to wander). Excessive caster angle will make the steering heavier and less responsive, although, in racing, large caster angles are used to improve camber gain in cornering. Caster angles over 7 degrees with radial tires are common. Power steering is usually necessary to overcome the jacking effect from the high caster angle.
Old 04-25-2013, 12:02 AM
First time's Avatar
Please do explain because I am trying to wrap my mind around this. I can understand excessive caster affecting camber gain but not the other way round.
Old 04-25-2013, 05:28 AM
I just got the car aligned, so maybe they just did an awful job?
Old 04-25-2013, 07:19 AM
First time's Avatar
Hopefully not that bad of a job lol.
Old 04-25-2013, 06:50 PM
downhiller's Avatar
livin large
i think it deals more with dual wishbone suspension. i read something on it awhile back i can be getting the 2 mixed now that ive been refreshing my memory
