Old 04-21-2013, 06:01 PM
marosmith marosmith is offline
Big Matty Wheels
Mein Auto: 2006 BMW 330i, 01 Allroad
2006 BMW 330i Bluetooth Phone issues
I have the standard stereo model, not the I drive.
Everything works with the stereo, radio, cd and Bluetooth connects to my iPhone 5 without an issue.
The problem is there is no sound for any of the phone functions, no voice, no mic picking up my voice, no ringing etc...
I have seen a few threads about this but none seem to actually give the solution. It seems like it happens enough where there should be a way to identify the problem.
It does not look like any modifications were done to this car, at all.
Old 04-21-2013, 06:12 PM
cneighbor's Avatar
cneighbor cneighbor is offline
Mein Auto: 2013 X1 Sdrive 28i MSport
Go to your trunk and unplug the Bluetooth module. I believe there's a couple of instructional videos on YouTube.
Old 04-21-2013, 06:15 PM
Big Matty Wheels
What will unplugging accomplish? Then do I replug it as some sort of reset?
Thanks.
Old 04-21-2013, 06:25 PM
cneighbor's Avatar
Exactly. It will reset the entire module. I had the same problem on my 330 twice and both times it fixed the issue. Unplug, replug, and resync your phone.
Old 04-21-2013, 06:32 PM
Big Matty Wheels
How can I know what part is the Bluetooth module?
Old 04-21-2013, 07:13 PM
cneighbor's Avatar
Driver's side compartment in your trunk. You'll have to do that YouTube search I mentioned. It's been a while, but I recall it's a pretty obvious looking plug. Unplug and replug. Kinda like resyncing your home modem. Pretty straight forward.
Old 04-21-2013, 08:51 PM
Big Matty Wheels
I was able to find it and tried this two times.
I noticed I do have the Logic 7 system. Also there is another plug which was wrapped up and not plugged into the amp. It appeared to be the same connection as the one that was plugged in. I tried plugging it in instead of the one that was plugged in, but this turned the assist and phone modes off when I rebooted the stereo so assume that was for an additional input of some sort.
Nevertheless I tried this and unplugging the standard cable and the same problem exists.
Old 04-22-2013, 05:37 PM
Big Matty Wheels
Any other ideas?
Old 04-23-2013, 07:59 PM
Big Matty Wheels
I do not want to take this to a shop for something that seems his trivial. Are there any other do it yourself diagnostics or things I should check out first?
Old 04-23-2013, 08:24 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Did it ever work?Also FYI
http://www.bimmerfest.com/forums/att...1&d=1366809492
If it works with and older phone it may not be compatible with the new one.
Also the extra optic cable near the amp is for the CD disk cassette player option.
Its not hooked into the most loop so leave it alone or as is.
http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf
File Type: pdf E90 ENTERTAINMENT AND COMMUNICATION.pdf (1.98 MB, 559 views)
Old 04-23-2013, 08:48 PM
Big Matty Wheels
I just bought the car so I don't know. I will try to get an older phone but I connected two iPhone 5's and my iPad all with the same results.
Old 01-02-2014, 04:08 PM
alep85 alep85 is offline
Mein Auto: A car :)
Any fix you've found? I have a 2009 328i that I retrofitted with a Bluetooth mic, and people still can't hear me.
