E34 (1989 - 1995)
Old 04-22-2013, 01:09 AM
markyss markyss is offline
Mein Auto: '92 BMW 525i Wagon
Unhappy Need help with diagnosis of load squealing and rough turning
Hi, i drive a 1992 525i and while i was driving last night i heard a strange pop noise. Then my car started to make a weird squealing noise that got loader when i gave it gas. Also it got very hard to turn the steering wheel. I think it may have to do something with the power steering pump but im uncertain. Please help if you have any idea what the problem can be. Thank you.
Old 04-22-2013, 06:30 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Welcome to the Fest.
It sounds like something is awry with your serpentine belt, i.e. it likely broke and part of it got caught in one of the rotating assemblies and is causing it to squeal. Raise the hood and take a look.
If the belt broke, make sure to check all of the rotating components such as the water pump. alternator, pulleys, etc. to make sure that they all spin freely. If so, replace the belt and you should be fine.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 04-23-2013, 09:17 PM
i checked it out and the belt feels really loose but its not broken. and as far as i can tell all the pulleys still turn.
Old 04-24-2013, 09:51 AM
BMR_LVR's Avatar
Humble E34 lover
Then the tensioner portion of the tensioner pulley is likely shot. They're not terribly expensive or difficult to replace.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 04-24-2013, 12:06 PM
ill give it a shot thank you again
Old 04-24-2013, 12:25 PM
BMR_LVR's Avatar
Humble E34 lover
My pleasure. Good luck and let us know if we can help further. Let us know what the final outcome is.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 04-24-2013, 12:26 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
If it breaks upgrade it. I had the tensioner go on me, which release the belt which shattered the w/p pulley etc. etc.
I got one of these and never looked back. It bolts right in. and when the little hydraulic goes, thats all you replace, rather than the entire tensioner. Worth every cent.
ECS M50 Hydraulic Tensioner Conversion
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 04-24-2013, 07:23 PM
Larrick Larrick is offline
Mein Auto: 1994 525it
Just to add my 2 cents: I was surprised at how little power steering fluid needs to be lost to compromise the steering.
My son's car had a small leak which we finally fixed by replacing a hose. They are expensive but safety first.
The steering would feel tight when the fluid was only a fraction low in the reservoir.
There were also leaks at the hoses under the reservoir which just needed new clamps.
Old 05-10-2013, 01:31 PM
I checked the power steering fluid and there was no leaks. I took both belts off and put new ones on , but the serpentine belt is still loose. So I figured that it must be the belt tensioner . Once i get enough cash ill go out and buy one.
