Old 04-22-2013, 10:20 AM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
Question re shifting from Manual to Auto
Is there some easy way to shift from Manual to Auto without moving the gear selector lever around? Suppose I'm in Auto (gear selector to the right) and I use the paddle to downshift to a lower gear. The system automatically puts me into M mode while the gearshift remains to the right. How do I get the car back into Auto? Do I have to slide the lever to the left and again to the right? In my C63 it was as simple as holding a paddle or the gear lever momentarily. Sorry if this has been answered a thousand times. Let's make it a thousand and one.
Old 04-22-2013, 10:39 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
If the shift lever is to the right (D mode) and you use the paddles, the transmission will shift to your selected gear for a short period of time (varies depending on throttle position) then will go back to Auto mode by itself.
If you have the shift lever to the left (DS or Manual modes) and use the paddles, it will stay in manual mode until you move it back to the right.
Old 04-22-2013, 11:43 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
It also works as Zooks527 outlined for the 7DCT.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 04-22-2013, 12:29 PM
So, assuming the lever is to the right in D mode and I use a paddle to go to M, there is no way for me to force the system back to D before it would do so itself automatically unless I slide the lever to the left and back to the right? If so, that blows. It would be nice if holding the + paddle for 1.5 seconds would put it back to D.
Old 04-22-2013, 01:51 PM
Zooks527's Avatar
That's correct. You can either wait the 5 to 30 seconds until it does it automatically, or you can do the "shift-left / shift-right". The time of the delay is shorter if you're near where the car wants the gear to be, longer if you're further away from its desired gear.
Old 04-22-2013, 02:59 PM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
The reason why BMW placed as it is for a safety issue, especially critical situations!
Old 04-22-2013, 03:41 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Step + paddles = 5 modes, none of which do what you want.
Hey. Were you aware the paddles worked in both shift stick positions when you purchased?
Old 04-23-2013, 06:13 AM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Lets try this again but without all the insults, etc. We have plenty of female BMW owners and enthusiasts here. Lets avoid referring to something in a gender discriminating way. There are plenty of other ways to express your dislike for something.
EDIT - In re-reading the OPs question I see no reason to have this thread play host to a manual vs auto discussion. I don't believe that is what the OP asked about, if you want to have that discussion start another thread or jump into one of the hundreds about the issues that already exist.
Tim
Old 04-23-2013, 08:49 AM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
We can be insulting on any subject.
