Old 04-23-2013, 02:46 PM
Houndz Houndz is offline
Mein Auto: 2008 E60 535i Sport
Sunroof drain cleaning?
Dealer wants $150 to clean my sunroof drains. Is there a sticky DIY cleaning procedure for e60's? I've been noticing a lot of people having issues with water in the trunk and footwells as a result of dirty and clogged drains. Thanks!!
Old 04-23-2013, 04:08 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
I have never seen a drain cleaning procedure posted, but then I live in SoCal so it isn't really an issue here. Both rainy days we get here are pretty light.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 04-23-2013, 04:16 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Which dealer are you going to, Stevens Creek? Never had that service offered before.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 04-23-2013, 04:20 PM
Phoenix1 Phoenix1 is offline
Sleeper Wagon
Mein Auto: 2008 E61
If you are at all concerned, then pay the $150 - vs $3000+ for new electronics...or if you have a sedan, you can have the electronic relocated higher...
2014 Audi A7 Prestige E61 SOLD 10/4/13! [/B]- 2008 E61/Monaco Blue/Natural Brown/Premium/Sport/Logic 7/Sirius. Escort 9500ci, Dinan S2 Tune (378HP, 417 ft/lb Torque), RD Sport Sway Bars. Conti DW and Michelin Xi3 snows. LED Angel Eyes, Matt Black Grill. Ext warranty until 2017!!!, 67K miles. Original owner. Fanatically Maintained, BMWCCA Member. Jersey
Old 04-23-2013, 05:18 PM
H F H F is offline
Mein Auto: 2005 545i
forget that Bro,, i just cleaned mine out,,, super easy,, u can get it done in 45 minutes taking ur time.. if ur interisted i can post some pics,,After cleaning them out the water flows right out,,, quick..
Old 04-23-2013, 06:28 PM
nickp3 nickp3 is offline
Mein Auto: 08 535i
Please post some pics. To the OP the dealer probably quoted $150 cause there probably at $150 per hour
Old 04-23-2013, 07:25 PM
H F H F is offline
First thing u do is remove the rear tires and the plastic fender well covers.
Then look at the top of the fender wells and you will see a cross shaped rubber piece. That stupid rubber piece is the culprit and the reason for all the problems.. it gets clogged and the water cant drain out fast enough, and backs up all the way up and overflows on the headlinner... U can see the dirt and grime in there, and is what stops the water from draining out.
take tha rubber cap off and run some weed wacker wiire up the drain hose (about 3 feet ) till it stops at the corner of the sunroof..
Then gently blow air into the drain hose with a tire filler and blow it out.. U can hear the air come out inside the sun roof. The water rushes out really fast now,,,, when i did the water test before,, it took a really long time. for the water to drain out
ID:	372843   Click image for larger version
ID:	372844   Click image for larger version
ID:	372845   Click image for larger version
ID:	372846   Click image for larger version
Old 04-23-2013, 07:34 PM
H F H F is offline
After blowing out with air... I cut the cross shaped rubber piece and made a larger opening so it will never get clogged again and reinstalled it.. After i drank a cold one ,,,put everything back it took like 40 min.. I think if u get pro active u can knock it out in 30 min.. So guys thats all there is to it.. hope this helps.
ID:	372854   Click image for larger version
Old 04-23-2013, 08:40 PM
booyaazaa's Avatar
Nice write up. My ride is usually garaged but I think a little preventive maintenance goes a long way.
2009 AW 535i
Old 04-23-2013, 09:05 PM
H F H F is offline
I have a garage queen too, and she sits in the garage all week. Only drive her on the week ends and my drains where clogged.but its not the drains that are clogged,, its that stupid rubber piece on the end of the drain hose that gets clogged...If any of u guys have water stains on ur head linner,, Someone said to use woolite ,, just wanted to say it worked good and got the stains out. Cant even tell they where there.. even after being on my head linner for over a year..
Old 04-24-2013, 07:46 AM
Campfamily's Avatar
Campfamily Campfamily is offline
Good post!!!
ADMIN: Can you make this a sticky?
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 04-24-2013, 08:52 AM
KLR4LIFE KLR4LIFE is offline
Mein Auto: 2008 550i Manual
What about the front drain hoses? Mine are not clogged but i want to clean mine out when i have free time over the weekend. I see the front drain out in between the front door jams.
2008 BMW 550i Carbon Schwartz Metallic, 6 Speed Manual, Sport Package, Cold Weather Package, Logic 7, Comfort Access, Active Steering, Sat and HD Radio, Navigation, Comfort Seats and custom coding. Mods - 20 Watt AE, LED License plate lights and HID Fogs, StopTech drilled rotors.
Old 04-24-2013, 09:52 AM
H F H F is offline
My front drains were clean and drained out quick, so I left them alone, there is a rubber elbow that points downward right next to the top door hinge, the front ones don't have that stupid cross shaped plug on the end, so they drain out good, the back ones are the problem, ill post some pic of the front ones later today
Old 04-24-2013, 09:55 AM
O ok, my font ones are good also. I poured a cup of water down the front and they drained fine. I want to take that cross shaped plug out of my rear drains just to be safe.
Old 04-24-2013, 10:40 AM
H F H F is offline
Ya ,, that plug is useless, it's amazing to me a 25 cent piece can cost thousands of dollars worth of damage, That is an engineering blunder, a total stupidity,
Old 04-24-2013, 10:54 AM
Still, it's a great write up you got here. Nice work Bro
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 04-24-2013, 11:57 AM
And you would think they would test these things but putting stuff in the channel to see how it gets stuck. Dam German's, seems like they focused on power and left everything else as trial and error for the customer LMAO! Just kidding.
Old 04-24-2013, 12:05 PM
LOl, actually the German fault is to OVER engineer everything.
2008 550i (R.I.P.)
2006 Jeep SRT-8
redhotdave redhotdave is offline
Mein Auto: 2008 535i
Great write up, i'll be doing this very soon. I relocated my electronics last spring, but I'd prefer to not have any water backing up causing any other damage.
thanks!
Old 04-24-2013, 01:31 PM
H F H F is offline
Thx bro,, actually i got tierd of looking at the water stains on my headlinner..Then ,it was more like exploratory surgery, when the water didn't drain out on the passenger side I started looking for the drain hose on the driver side cause it was draining water out, had a hard time finding it . The water was just leaking out the back of the plastic fender well cover, So that's when I decided to take the cover off , looked up and there was that dumb ass rubber piece all clogged up,,
Old 04-24-2013, 01:35 PM
H F H F is offline
I'm like dumb founded by that, they had a serious brain fart,, LOL,,,they only put that rubber piece on the rear , and not the front ,it's just stupid .
Old 04-24-2013, 06:03 PM
H F H F is offline
Heres the end of the front drain exit looking straight down over the pasenger door hinges.... Bmw got the front right... Good thing they left the caps off on the front side....
ID:	372984   Click image for larger version
ID:	372985   Click image for larger version
Old 04-24-2013, 06:29 PM
That's how mine looks also, thanks.
Old 04-24-2013, 06:37 PM
Image2Pixel Image2Pixel is offline
Mein Auto: 2013 X3 xDrive
My guess is that because the front drain is inside the door jam that it is protected enough to not put the other piece on the end. The rear drain is probably exposed, so they wanted to keep out dirt and debris (from the outside) by using the end piece. Unfortunately they didn't think that the dirt and debris would come from up above.
Old 04-24-2013, 07:15 PM
H F H F is offline
Actually the rear is not exposed at all, it's behind the plastic fender well cover, the pics I posted are after the fender well covers are removed.The Deal is water pushes dirt and grunge down the cassette rails and down the drain tubes , and gathers on the inside of that cross shaped rubber piece.
