Old 04-23-2013, 09:54 PM
amit1947 amit1947 is offline
Mein Auto: 2014 BMW M5
Start Up Hesitation with Video!
Ok so I captured my long start up and hesitation video. This only occurs after letting the car sit for several hours. After starting up, the idle seems smooth. No CEL.
Here's the youtube link:
What could this be?
Old 04-23-2013, 10:04 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
I bet it is the fuel pump. Search for BMW HPFP
Old 04-23-2013, 10:18 PM
Yes I know about the HPFP, but it was replaced on this car before I bought it (CPO) last year. And I thought the HPFP issue was "fixed" by now. But who knows, maybe the pump they used is an older revision, I think it was replaced in late 2011.
I am thinking it could be the fuel injectors leaking fuel, while the car sits, or a bad LPFP/sensor, or even carbon build up on the intakes. The car has 46k miles on it and the spark plugs were just replaced at 40k (routine service). All 6 injectors were replaced about 10k miles ago as well.
Old 04-24-2013, 06:53 AM
l1tech l1tech is offline
Mein Auto: 09 528i
If it is a leaking fuel injector usually the car would act flooded when you try to restart and should stumble a bit when it starts. To me it seems like the fuel pressure is bleeding off. the engine cranks until the fuel pressure comes up and then it starts and all seems well. Possibly a defective check valve in the fuel pump
Old 04-24-2013, 07:18 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
2006 530i does not have HPFP, it has regular fuel pump.
As others suggested, fuel pressure regulator may not be holding the pressure. When was the fuel pump replaced? Did they replace the fuel filter as well at that time?
At 45K miles, with the fuel pump already replaced, now I am not sure if it is fuel pump issue.
Old 04-24-2013, 07:54 AM
My mistake. I havent updated my profile. I have a 2010 535i.
Old 04-24-2013, 12:39 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
Have the dealer take a look at the HPFP again and the fuel rail, since those also get clogged and fail.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 04-25-2013, 01:46 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
What sort of fuel pressure is used in direct injection engines?
Old 04-25-2013, 01:50 PM
535kjp 535kjp is offline
Mein Auto: 2011 535i XDrive
my 2010 started just like this predominantly on cold starts like overnight. Dealer changed the HPFP and Low Pressure Fuel Sensor and it seems to have remedied the problem for now
Now my problem is misfiring, so I'll probably go back to get the injectors changed. I also realized today that usually when I start the car in the morning, it will start at an initial RPM then about a second or two later raise higher like its getting more power. So it might start at like 900 and raise up to 1200 or so a second or two later
Old 04-26-2013, 05:29 PM
I took my car to the dealership this week.
So I got a call from the SA telling me that the long crank was being caused by the HPFP. This was replaced.
I also had a bad "leaking" injector #4 which resulted in all 6 injectors being replaced by the newer "2013" style parts.
Here is the service paperwork:
Old 04-26-2013, 05:32 PM
I am assuming that the pressure test result for the HPFP (5.5 Bars) was the failure?
Does anyone know what the pressure should be?
