Old 04-24-2013, 11:20 AM
omiv21 omiv21 is offline
Mein Auto: BMW 325 xi
19's without Lowering?
Guys I'm sorry if this has been posted before, but to you, this may be considered a dumb question. For my car (06' BMW 325xi), will 19's fit without lowering it? If so, is there a certain tire size that will work?
My stock rims are 16's. I attached a photo so you can see what I'm working with.
Any help is appreciated.
Dave
Old 04-24-2013, 11:27 AM
floydarogers's Avatar
Pedant and Curmudgeon
Yes. See tirerack.com for wheel and tire sizes.
Old 04-24-2013, 11:37 AM
should I be going staggered? different size rim in the front vs. back? does it matter? does it help? does it look better?
Old 04-24-2013, 11:40 AM
tturedraider's Avatar
Freedom isn't free!!
19s will fit fine. Lowering the car is not necessary for larger wheels. It actually could create the possibility of having issues with the fitment of larger wheels. Check TireRack for appropriate tire sizes.
www.bmwcca.org
Old 04-24-2013, 01:44 PM
Is it worth the rough ride getting 19's vs a smoother ride on 18's? I have been searching photos and 19's definitely look better but not sure. Any of u guys have 19's and don't notice a difference? Would like to see pics if possible.
Old 04-24-2013, 01:51 PM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
The lower the profile the rougher the ride so 18" tires are a better choice than 19's. Looks are the only reason to go for larger diameter wheels on your car.
Also, you will get better fuel economy and better handling with the smaller wheels. Larger wheels are heavier.
Old 04-24-2013, 02:31 PM
No.
www.bmwcca.org
Old 04-24-2013, 02:41 PM
captainaudio's Avatar
Worlds Foremost Authority
Originally Posted by omiv21;7541264[B
]Is it worth the rough ride getting 19's vs a smoother ride on 18's?[/B] I have been searching photos and 19's definitely look better but not sure. Any of u guys have 19's and don't notice a difference? Would like to see pics if possible.
Only if you have are are a rapper with a record contact and the word "Ice" is part of your name.
CA
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 04-24-2013, 02:47 PM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
You sure about that? I mean, if the circumference of the wheel/tire combination is the same, the only way 19's are heavier than 18's is if the aluminum weighs more than the rubber. And even if it does, I've gotta believe we're talking c-hairs here.
Old 04-25-2013, 07:37 AM
Moderator
Check out this test Car and Driver did a few years ago:
http://www.caranddriver.com/features...d-tires-tested
The 19" tire/wheel combination is 3 pounds heavier per wheel than the 18 and 6 more than a 17" combo.
Old 04-25-2013, 11:12 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Depends on the wheel. I have 18" 313 on one car & 19" 313 on the other will pay with the weights during the summer when doing a
"clean the winter off the bottom".
That being said its my understanding, could be totally wrong heard it second hand, that the 19" are BBS forging & the 18" are BMW castings. That will also effect the weight & certainly the strength of the wheel.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 04-25-2013, 03:22 PM
CT's Avatar
CT CT is offline
GODSPD
Mein Auto: SSII E90 ///M, AW E92 N54
The weight of a cylindrical object increases by the square of the radius. Aluminum has approximately ten times the density of tire rubber.
e90m / ssii / foxred / nochrome
wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer
full challenge exhaust
WHEELS FOR SALE
Old 04-25-2013, 08:12 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
Punched some simple stuff into a spread sheet to take into acct larger wheel also has larger inside diameter. The Di being bigger is a competing effect to wheel being heavier. Anyway, i assumed 8.5" wide wheel, 19 Do and 18" Di (thickness is 0.5", i know that is too thick). Compared this to same thickness 18" Do and 17" Di with same width. Larger wheel is 1.34 lb heavier. The tire for the 19" wheel will slightly decrease in weight but we are only talking about the sidewall getting shorter by 1/2". Larger wheels are heavier if you run the numbers.
This is why the hybrids runs the little wheels. The other advantage of running smaller wheels from an economy standpoint is a lower radius of gyration. Basically think about the figure skater that is spinning and then she brings her arms closer to her body and accelerates the spinning speed. Same weight of arms but more efficient spinning speed.
I wanted to go to 19" wheels too but read too many people tearing wheels up with the shorter sidewalls. I actually considered going to a taller series for the 18"s my car uses. I did not do it as i didn't want to kill the fuel mileage by using heavier tires. I enjoy the ~ 40mpg the D gets on the highway. I got a more smooth ride instead by going to go flat tires. Go flat is funnier term than non run flats.
Personally, if it were me i would get 17" wheels with square set up (same size front and rear) to allow front/back tire rotation and keep the somewhat taller sidewall by having the 17s. The tires will be cheaper this way too. 19" tires cost more than 18s that cos more than 17s. You will lay out serious $$$$ to go to 19s.
Looking back at your car, it is an 325xi. All the more reason to be running a square setup.
Old 04-25-2013, 09:17 PM
mentos876 mentos876 is offline
Mein Auto: 2006 e90 330i
it will fit with no problem, but it will look kinda funky
Old 03-18-2014, 01:07 AM
matreyia matreyia is offline
Mein Auto: 335i Convertible 2009
Hi Kevin,
Quick question for you. Were your 19" 313 heavier or the same weight as your 18" 313 set? I been trying to find the answer to this for months to no avail. Thanks for your time. I hope you still have your cars!
VT
Old 03-18-2014, 07:21 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Pish-posh! There are very good reasons to go 19", even 20" or more!
Just think of the stiffness available with larger wheels. Cornering is so enhanced....and the way they fill the wheel well is an aerodynamic plus.
See here Mr. Schott, as most of us are aware, you've outed yourself. You will soon be leaving the BMW marque for inferior, possibly Oriental Engineering. Thus, a spoonful of salt must be taken with your comments, and being as how you're on borrowed time, we cannot take your comments as "Gospel." No.
I'm sure OP is aware of helium fill to offset heavier wheels. Other options such as Nitrous Oxide, the gas that yields a "lighter than air" feel to the car, have been explored. I do not believe larger wheels should be a negative for OP.
Consider the larger wheel profile to be a "canvas" - imagine what could be done! Options run from colors to actual video while in motion, enabled by timed LED's. OP - let no holds be barred!
Old 03-18-2014, 08:06 AM
Mein Auto: '06 AW 330xi
The wheel gap killed me. I'm now lowered on coilovers.
I'm running a square setup of 19 x 8.5 wheels with 235/35/19 Michelin Pilot Super Sports.
This is a really old photo of my car. I had BF Goodrich g-force tires mounted. They were loud as hell. Lots of road noise
Old 05-31-2016, 06:59 AM
smak91 smak91 is offline
///Member
Mein Auto: 2013 328i xDrive
Loud as hell indeed!! It sounds like an airplane when accelerating
