Old 04-24-2013, 04:49 PM
jbyron jbyron is offline
Mein Auto: 08 335ix Sport
Inner door sill - what's the trick?
This morning dropping her off at school, my daughter accidentally pulled up the inner sill/kick panel on the passenger side. What's the trick for re-attaching? I can get the front two, or the back two, but not both.Click image for larger version
jbyron
St. Louis, MO
2008 335xi Sport
50,xxx mi
1999 540i Sport - Retired w/202,xxx
1997 540i - Retired w/162,xxx
Old 04-24-2013, 05:08 PM
sandjam sandjam is offline
Mein Auto: 2010 328i M Sport Vert
you need to remove the clips from the floor, then slide them back on the trim piece and then install it. I usually take a needle nose pliers and get under the clip and squeeze in the clip to remove. Sometimes they break and you'll need to get new ones.
They work like the clips on the door panels except they don't come out easy like the door panels.
Sean
Old 04-24-2013, 05:19 PM
Perfect! Thank you. 90degree needle nose pliers worked perfectly to pry the clips.
jbyron
St. Louis, MO
2008 335xi Sport
50,xxx mi
