Bad Missfire - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 04-24-2013, 07:02 PM
scharf1 scharf1 is offline
Mein Auto: 84 318i
Bad Missfire
So i have a nasty miss between 2k and 3k rpm. It runs fine after that. When i put my foot on the gas it will just spit and sputter, sometimes dieing and sometimes it will rev up with a little feathering. So i checked plugs, wires, cap and rotor first to eliminate that. I then unplugged Throttle Positioning sensor to see if it made any change, it didn't do anything. MAS looks good. its not throwing any codes. Could timing cause it to be that bad? what else should i check?
Old 04-25-2013, 02:20 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Clean out the tracks on your VAF
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 04-25-2013, 06:53 PM
downhiller's Avatar
livin large
check the wiring to the cps and i would test the tps a bit more
Old 04-25-2013, 07:00 PM
Mein Auto: 84 318i
i was going to test the resistance on the tps as soon as i can. ill look into those others and see whats up. thanks
