E30 (1982 - 1993)
Old 04-25-2013, 10:28 AM
gamma gamma is offline
Mein Auto: bmw e30 325i
Exclamation Bmw e30 325i 1989
Hi, i've changed the fuel regulator, the gaz pump, the line are new and there is no leaking. When i turn the key it takes 5-10seconds to start. It crank for long time and it runs good after. If i stop the car for a short period, it start fast. But after 30minutes or more. Hard to start again. It's weird cuz during the winter when it was super cold, the car started directly, faster then any new car, even below 20celsius.. If you have an idea about what is the problem help me please! now i check about the crank sensor..
Old 04-25-2013, 06:10 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
Bmw e30 325i 1989
Check Crank sensor.
Old 04-29-2013, 02:37 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Sounds like the fuel pump or FPR is allowing the fuel to drain off.
So after a while of standing the system first needs to be filled again.
Or the idle is set too lean...
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 04-29-2013, 05:59 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
You may have an injector leakage problem.
m
e30 325i, problem starting
