Old 04-25-2013, 05:57 PM
rajeek's Avatar
rajeek rajeek is offline
Mein Auto: ///M7
Paddle Retrofit.....Success!
Well the 2nd try worked out to be the charm. Got my F01 fitted with functioning paddles and upgraded to the M-Sport steering wheel as well. Eventually I had to swap out my steering wheel control cluster along with my old sport steering wheel. Only one issue is I have to be in DS driving mode for the paddles to work. Apparently this is how the 7's are coded I am told. They won't work in just regular driving mode. Nevertheless, I LOVE THEM! So nice to fully have instant control of the transmission whenever I want, really changes the feel of the car!
Here are some pics.
Parts needed:
1. New M-Sport Steering wheel with paddles (Cost me $730)
2. New Steering cluster - $420 (Part # 61319297781). You may not need this if you car is a later model and has this new one already. Mine didn't which is why the first try failed.
3. Airbag? If you have an M-Sport wheel or regular Sport wheel already your airbag is interchangeable. If you have a non-sport wheel you will need a new airbag. Can be pricey new. eBay is probably your best bet for this item.
From what I know I was the first one ever to get an F01/F02 successfully retrofitted with paddles!
If you want your own set talk to Patryk. www.bimmer-tech.net Also email at info@bimmer-tech.net
Options: Executive Package, M-Sport, B&O Sound, LED Lighting, Drivers Assist, Active Cruise. No RWS (Rear Wood Shelf).
Mods: BMS n63tu Tune, PedalBox, H&R Sport Springs, RD Sport Front Lip, Rear Roof & Trunk Spoilers, 20" Forgestar F14 Rims, Akebono Ceramic Brakes, 20% Front/15% Rear Tint, Carbon Fiber Wrap, Smoked Taillights, 760 Exhaust Tips, "Golf Tee" mod, Kidney Grills & Front Vents Painted Gloss Black, Brake Calipers Gloss Black w/BMW Logos, B&W Carbon Fiber Roundels.
Old 04-25-2013, 06:22 PM
Bimmer750LI's Avatar
Bimmer750LI Bimmer750LI is offline
Mein Auto: 750Li
Great upgrade, so it didn't need the updated steering wheel control unit in addition to the control stalk switch assembly? That's even better and keeps the cost down. Def my next mod, can't wait.
Old 04-25-2013, 06:29 PM
rajeek's Avatar
Mein Auto: ///M7
Just wanted to add. Don't forget to sell your old steering wheel and steering cluster (if needed). That will certainly put this in the affordable range for most all after net costs.
Old 04-25-2013, 06:51 PM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
Superb work!
Currently: 2015 Porsche 911 GTS and 2016 Cayenne S eHybrid
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 04-25-2013, 07:19 PM
wjjklj's Avatar
wjjklj wjjklj is online now
Mein Auto: 2013 BMW 750Li X-Drive
I did this on my 3 series awhile back. You have to click the shifter over in DS mode on that model also.
Old 04-25-2013, 07:24 PM
rajeek's Avatar
Mein Auto: ///M7
Only needed new wheel and control stalk that is all. Some later MY cars will not even need the latter.
Old 04-25-2013, 08:16 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
Rajeek, If I already have an M-sport steeing wheel, do you think I could just add the paddles? Did Patryk need to code anything or would just have adding the parts (wheel/control stalk) make it work?
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 04-25-2013, 08:26 PM
rajeek's Avatar
Mein Auto: ///M7
Sadly no. There are cutouts at the back of the wheel that need to be there for the paddles to be installed. It has to be a paddle specific wheel. You could just buy the bare bones wheel and use all the other stuff from your wheel now, but the wheel needs to be replaced at a minimum.
Yes, special coding is required to get them up and running.
Old 04-25-2013, 08:29 PM
aom aom is offline
Moderator
Thanks! That makes sense... Just a quick question, could sell my M-sport wheel to someone w/ a regular wheel or are the airbags not compatible? (since I assume I can keep my existing airbag if I upgrade to an M-sport w/ Paddle wheel)?
Old 04-25-2013, 08:37 PM
Wolfman64 Wolfman64 is offline
Mein Auto: 750li, S550, SL550, ML350
Congrats! Awesome mod!
Still don't understand why BMW has you switch to DS. Must the only brand to make you work before you can enjoy steering wheel paddles
How fast is the shift response?
rajeek's Avatar
Mein Auto: ///M7
Talking
Good question. Air bags are interchangeable between M-Sport and regular sport wheels. Non-sport wheel will require a new air bag. I had a sport wheel already so that was just reused.
Will update my original post with that info.
Old 04-25-2013, 08:42 PM
rajeek's Avatar
Mein Auto: ///M7
I was a bit sad about the DS thing, but still thrilled to have paddles. Response is instant. Same as all other BMW's with factory installed paddles that I have driven.
Old 04-25-2013, 09:10 PM
aom aom is offline
Moderator
Cool, thanks for the info!
Old 04-25-2013, 09:20 PM
Zaman Zaman is offline
Mein Auto: 2012 528i XDrive (F10)
I want to change my F10 regular wheel to sport one and I don't care about paddles alot. Do I need to change the steering cluster or my current one would work? I guess I just need the wheel and the airbag. Am I right?
BMW F10: A Formula to Captivate the Senses.
2012 528i XDrive, Alpine White
Old 04-25-2013, 09:29 PM
rajeek's Avatar
Mein Auto: ///M7
You will need a sport wheel and a new air bag. That is all.
I have a pristine sport wheel that I will be putting up for sale. PM if interested.
Old 04-25-2013, 10:13 PM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
Do they make a central airbag cover/module that's smooth rather than textured? Seems like a smooth one would go better with that M steering wheel.
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 04-25-2013, 10:53 PM
jeffnin jeffnin is offline
BMW Addict
Mein Auto: 16 750i, 15 i3, 15 428GC
Great job on the retrofit! I really miss the paddle shifters as I've had them on my past 3 BMWs. Unfortunately, my 7 Msport was an early 2013 build where an error in the ordering system didn't include the paddles with the MSport package. BMW offered to build me a new car or just give me a credit, so I just took the latter, but I miss the paddles for those times where you need to shift instead of having to use the beer tap shifter. And FYI, all BMWs with paddles only work in DS mode.
2016 750i Black Sapphire/Black|Driver Assist Plus|Driver Assist Plus II|Executive Pack|Interior Design Pack|Wood inlay Wheel|20" M Sport Wheels|Integral Active Steering|Display Key|Ambient Air|Pano Sky Lounge|Bowers & Wilkins
Past BMW's: 15 335i, 13 740i, 12 328i, 12 X5, 09 335i, 07 X5, 07 335i, 04 545, 01 525i, etc....
Old 04-25-2013, 10:56 PM
BMW Addict
Negative on the smooth airbag cover. It's the one cheap thing that the 6er and 7ers with Nappa leather option should provide. The airbag cover would look so much better with leather stitched cover or at least a smooth vinyl finish as opposed to the grainy look that is same in a 1 series.
Old 04-26-2013, 12:17 AM
Patrys@BimmerTech's Avatar
Patrys@BimmerTech Patrys@BimmerTech is offline
Mein Auto: BMW
Thanks Raj for choosing BimmerTech... again!
If anyone is interested in doing this retrofit we still have brand new M sport steering wheels with paddles in stock now. We can supply the complete kit to retrofit the paddle shifters in any F01/02 or F10.
Drop us an email with your VIN and location to get a quote.
BimmerTech
Phone (USA): (646) 439-7920 (7:00am - 3:00pm ET) :: info@bimmer-tech.net :: www.bimmer-tech.net
Installation facilities worldwide.
Tb750 Tb750 is offline
Mein Auto: 750li
beauty! question how did you get your speedo gauges like that!?
Old 04-26-2013, 12:37 AM
aom aom is offline
Moderator
Sent you an email.
Old 04-26-2013, 02:34 AM
Mein Auto: BMW
http://www.bimmer-tech.net/shop/bmw-...panel-retrofit
BimmerTech
Old 04-26-2013, 08:06 AM
dbs600 dbs600 is online now
Mein Auto: 2011 750LXi Individual
Now that you've had them for a while, how do you like your new gauges? Do they still have that 'wow' factor to you yourself (not others who see them for the first time) or has the novelty worn off? Are they any more functional in everyday use (i.e.: are navigation indicators on the cluster more useful than on the prior cluster)? Do they feel any less 'luxurious' than the analog instruments? Wondering your actual thoughts...
Old 04-26-2013, 08:46 AM
chrischeung chrischeung is offline
Mein Auto: 2008 Mazda 6
Very nice indeed.
2 questions if I may:
1. How do you tell if you need the new steering cluster or not?
2. Do you need to recode the car after making the steering wheel change?
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 04-26-2013, 09:07 AM
rajeek's Avatar
Mein Auto: ///M7
I still love the new panel. My only wish and this is just personal preference is that the sport red dials would only appear on Sport + vs Sport/Sport +. That is all. Otherwise still love it. It also displays 5 lines of info for songs and phone lists which is very nice.
