Old 04-26-2013, 05:41 AM
jgallinagh jgallinagh is offline
Mein Auto: 2009 535i
2009 535i Hard Start & Radio Issues
I'm looking to see if anyone has experienced a similar issue to what I'm having with my 2009 535i. Recently, I've been having a fuel delivery issue when starting, causing a hard start. When I press the start button, it takes a little while for the the car to start and I suspect it's a fuel delivery issue. Shortly after the hard start issue started, my radio went inop. Anyone know if these two issues could be related?
Old 04-26-2013, 06:12 AM
amit1947 amit1947 is offline
Mein Auto: 2014 BMW M5
I just took my car in for this yesterday. They replaced the HPFP and all 6 fuel injectors with the new style n63 V8 part.
I uploaded a video to youtube showing the long crank issue. Theres a link to it in my other topic.
Old 04-26-2013, 06:14 AM
Heres the link
http://www.bimmerfest.com/forums/sho...d.php?t=691730
By the way, I didnt have the radio inop issue.
Old 04-26-2013, 06:15 AM
Yep, that's what I'm seeing with the hard start issue. Did the dealership charge you for this work or was it covered under the warranty?
Old 04-26-2013, 06:22 AM
100% warranty. This is a defective part.
I still have a few more months of original warranty, and then 2 more years of CPO warranty.
Old 04-26-2013, 06:23 AM
Sweet!!!
Old 04-26-2013, 06:25 AM
Its funny how at least 3 of us on here are having similar problems at the same time.
Old 04-26-2013, 06:43 AM
Hoping to get the car into the shop ASAP. I'll keep you posted on whether it's the same issue or not.
Old 04-26-2013, 08:01 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
You need a check engine light before dealer will start looking at injectors.
Your problem seems to be weak battery, low pressure pump will prime the HPFP and injectors when you hit unlock button or when you insert the key fob into ignition, when batt is low in charge this process is not done properly, making HPFP starve of fuel.
Charge the batt to see, it's the easiest thing to try.
Old 04-26-2013, 08:03 AM
Interesting... I have had several low battery warnings in the past and the car does sit a lot since I work from home and travel a lot.
Old 04-26-2013, 08:05 AM
I had no check engine light.
I guess it could be a low battery but then you would have other symptoms like a resetting clock or wierd/random error messages on idrive.
Old 04-26-2013, 08:11 AM
Just took it for a ride and got a SOS Call System failure error....
Old 04-26-2013, 08:25 AM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
Sounds like the battery is the main culprit for the errors. I'd get a new battery (not the $900 dealer one) and then take it in for the injector/HPFP issue Amit mentioned. Eliminate their excuses.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 04-26-2013, 08:33 AM
There are more symptoms with this as well. Not only am I getting the SOS Call System error, but none of the iDrive buttons/knobs work either and neither does the bluetooth connectivity for the cell phone. Still think it's a battery issue?
Old 04-26-2013, 08:57 AM
Wow, talking about going from bad to worse.
I'd hook up your car to battery-tender or charger for a few hours to see. Won't harm anything since it's easy to do then see if your car behave a bit.
GL bro.
Old 04-26-2013, 09:01 AM
Still quite possibly a battery issue, you'd be surprised how sensitive these cars are to voltage fluctuations. The problem is that is you take is it for the hesitation/rough idle they will say it's the battery and replace it (for $900) and it won't cure it - as Amit can attest to. Which is why I suggested a new battery first then take it to the dealer.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 04-26-2013, 10:02 AM
NoQuarter's Avatar
NoQuarter NoQuarter is offline
Mein Auto: 2008 535xi
Done any radio/CD/SAT Radio/HD Radio type work lately? These problems can also be due to the fiber optic MOST link being disconnected.
Old 04-26-2013, 10:35 AM
none of those thing work. I just had the car detailed and I wonder if he knocked something loose? the radio controls worked intermittently last night but then stopped all together this morning. I think you are onto something here. where is this connection?
fuel delivery, idrive, radio
