Old 04-26-2013, 07:19 PM
matrix4583 matrix4583 is offline
Mein Auto: BMW Z4 3.0SI
BMW Z4 3.0SI gas cap light sensor problem
Hello fellow Bimmers,
I am a new member here and I was wondering if you guys can help me out. I have a gas light sensor problem. When ever I refill my gas, the gas cap light should be on to tell me that my cap is not close and it needs to be closed; but the car doesn't tell me that. Also I purposely open the gas cap to see if the light is on, but it wasn't; so, I was wondering if you guys can point out to where I can fix this? Thanks.
Old 04-26-2013, 08:32 PM
ebruder's Avatar
ebruder ebruder is offline
Mein Auto: '07 Z4MC, Porsche 928S4
I don't mean to rag on you, but in my several years on this forum this is the first time I have ever seen a question regarding a non-report of a non-problem.
Most issues such as this are of people asking why a "problem light" ls lit when there is no problem. You are asking the opposite. I suppose you might have found a non-warning when you desire one, but I would just let it go and enjoy your car.
EB
Old 04-26-2013, 08:48 PM
Smile
EB
I understand, but the problem is that when ever I put gas into the car; I forgot to close the cab, so I need to find a solution in order to fix this. I do love my car by the way. Every time I drive that car, people always stare at it. It is a black color with black rims.
Old 04-26-2013, 08:57 PM
ebruder's Avatar
If is that important to you, then if you have not done so already, try to simulate exactly what you do when you fill up. Turn off the car completely. Remove the gas cap completely, and then either leave it off or put it on loosely. Start the car and drive a few hundred feet.
See if you get a warning light then. Some of the lights only come on when a real driving issue is at hand. This might be one of them.
Good luck.
EB
Old 04-26-2013, 09:10 PM
Good luck.
EB
I did try your method today and that was like 2 hours ago; I didn't fill up my gas though, because the gas station there doesn't accept my credit card for some reason, so I went to a new one. While driving to a new gas station; I notice that my gas cap was open and the light didn't turn on. The light usually turn on immediately after I forgot to close it, but not tonight.
Old 04-27-2013, 06:44 AM
tonywintn tonywintn is offline
Drivin' the dream
Mein Auto: 2005 BMW X5 & 2007 Z4 si
The OBDII system does periodic system integrity leak checks. It does the system leak check within a certain fuel tank level range; so while the system may not detect a loose or missing gas cap immediately, it will eventually. Keep in mind that the purpose of the light is not to tell you the gas cap is loose. It is verifying that the entire fuel vapor management system is not leaking hydrocarbons into the air and destroying the planet. All of the vapors generated by a fresh load of gasoline are directed into a charcoal canister where they are held until they can be burned off by the engine. In the olden days, gas tanks were vented directly into the atmosphere. In this case newer is better. I don't miss the odor of fumes myself.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors
Old 04-27-2013, 06:49 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
The solution is "To Close The Cap". Take an 8"x12" piece of paper and write, in large letters, "Did You Close The Cap?" and tape it to your console.
Old 04-27-2013, 11:01 AM
lol.
