Old 04-27-2013, 01:32 PM
BimmerBoy1986 BimmerBoy1986 is offline
Mein Auto: 2007 335i Sedan
Exclamation 2007 335i Sputtering
Ok so about three weeks ago while I was driving home one day engine started to sputter at 2500 rpms and a very bad sounding idle. Stopped and got the code read(Already had code P2402 DMTL Pump) so no new code. Started her back up and idle was good and the sputter was gone. A week later same thing happened so I turned off the engine and restated it and once again the sputter was gone. Has happened twice more since then. Anyone have a clue
Bad Plugs?
Bad Injectors?
HPFP ?
Old 04-27-2013, 02:31 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Bad Plugs?
Bad Injectors?
HPFP ?
What's the mileage?
Old 04-27-2013, 11:29 PM
galahad05's Avatar
galahad05 galahad05 is online now
Better with Butter
Mein Auto: 335i sedan 6MT
For me, I had a similar experience, though it ended up much worse than yours (is now).
I ended up changing all plugs and one coil, followed by replacement of all injectors.
Didn't fix the problem.
The root cause in my case? Carbon fouling on the intake valves.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 04-28-2013, 04:35 AM
Banned
Mein Auto: 2007-335 HTC
I find it hard to believe carbon fouling on the intake valves would cause an intermittent sputtering, I would think it would run rough all the time, I would check to see if your High pressure fuel pump has been replaced, spark plugs? maybe..
I would think once a coil went bad it would stay bad unless it goes out when it gets hot, If you have tons of money, then replace all the plugs, all the coils, and injectors, and have the intake walnut blasted and replace the HPFP then you have a 90 percent chance you got the culprit
Old 04-28-2013, 05:45 AM
Phil325i's Avatar
Phil325i Phil325i is online now
Mein Auto: 325i E92 Coupe
Erm...why not take the guesswork out if this and avoid unnecessary expense by going to a reliable indy and getting the fault codes read?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 04-28-2013, 05:48 AM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
That would have to be really bad...
I'd do in this order:
Intake valves
2-4 gallons of e85
coils/Plugs
Fuel injectors
Old 04-28-2013, 07:09 AM
Banned
so whats E85 going to do? Right now thats one problem is the Alcohol in Gas, How about we go back to 100 percent gasoline!
Old 04-28-2013, 07:11 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Even if any of the above offers are correct, it's gonna cost you if you're of warranty. N54 club FTL
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 04-28-2013, 09:25 AM
Mileage is 92k. The fact that it comes and goes is whats bothering me. Just change jobs so I wont have play money for about a month.
Old 04-28-2013, 09:27 AM
Will most likely do this on Friday my next off day.
Old 04-28-2013, 10:48 AM
galahad05's Avatar
Better with Butter
I have no idea why, but my symptoms were exactly like OPs....at first. But the symptoms over time got worse and worse until finally it turned into a permanent 5-cylinder operation (constant misfire in cylinder #2).
Theory:
It's like.....variable combustion chamber quality, based on outside air temp, how I'm driving it, whatever, and of course the carbon fouled intake valves, effecting how hard it is to fire off the fuel/air charge at any given moment. Sometimes it fired okay (enough), sometimes not at all. This stressed out my plug and coil with essentially uncontrolled combustion conditions. Eventually, the spark system on the worst-effected cylinder just wore out.
-- Irish Proverb
Old 04-28-2013, 11:53 AM
lol I just shot off an email to my SA about doing all my coils and plugs if I can get near the getbmwparts price + an hour or two of labor I think I'll bite.
Old 04-28-2013, 12:43 PM
Banned
you can replace the coils and plugs your self, thats plug and play stuff, if you have to do the intake valves it might be worth having someone do it
Old 04-28-2013, 01:04 PM
I'm aware of that but as this would be a first time DIY its probably best not to start a day before class and the last week before finals
Old 04-28-2013, 01:09 PM
If never done, you're way overdue for a walnut shell blastin'. Frequent cure for misfires - just Google or SEARCH for more info.
Or, you can do it the hard way - hate that.
Spend couple o'hundred $ for the first procedure - you'll be soooooooo glad, and soooooooo much smoother....then, can do again as needed for next to nothing. Dealer: $600
Old 04-28-2013, 02:19 PM
indy 300-450
Old 04-28-2013, 02:23 PM
Got a great one named Motorcepts around here going to give them a call most likely get it done next month.
Old 04-28-2013, 02:42 PM
galahad05's Avatar
Better with Butter
For the record I just recently installed an oil catch can. Hopefully this will take care of the carbon fouling issue going forward.
-- Irish Proverb
Old 04-28-2013, 02:59 PM
It won't. Plenty of people have removed them and still find enough carbon that it would be worthy of a blast.
Old 04-28-2013, 03:11 PM
Hey G - sorry to say: improvement yes - cure no.
There is work in progress re: volatile components of engine oil, and initial result, but no cure.
Old 04-28-2013, 03:43 PM
galahad05's Avatar
Better with Butter
Well that sucks.
-- Irish Proverb
