Old 06-03-2013, 08:28 PM
firefox firefox is offline
Mein Auto: 2009 750i
temperatures
I was curious as to the temperatures of the kit when it is all connected. I measured at 75 deg F room temp.
Heatsink on the light bulb - 164 deg F
Resistor - 138 deg
Driver - 90 deg
The heatsink on the bulb gets really hot. So I have made sure not to have any wires touching the heatsink. Perhaps it would be better to have a bigger heatsink or a fan on it. Feedback for V3 maybe.
I've been getting error codes off and on. But the angel eyes always work. I'm not even going to bother with the resistor.
Temps will probably be higher in an enclosed headlight.
I did not observe any melting after 30 minutes of driving at least.
With the resistors it is pulling 1.17A.
Without the resistors is is pulling 0.869A.
Love the look of the bulbs in any case.
Name:	WP_20130603_006 (Large).jpg
ID:	380096   Click image for larger version
Name:	WP_20130603_012 (Large).jpg
ID:	380097   Click image for larger version
Name:	WP_20130603_016 (Large).jpg
ID:	380098   Click image for larger version
Name:	WP_20130603_018 (Large).jpg
Old 06-03-2013, 09:40 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Re: TXSTYLE Reviews: Mtec v2 LED Angel Eyes
That's some TESTING there lol!
Nice going man. Mine are still going strong for nearly two months. Just as bright and I've monitored the install and no issues enclosed. Although I may look to wrap the wires in black snake tubing just as a precaution.
~Big Marcus
Old 06-06-2013, 09:02 PM
rajeek's Avatar
rajeek rajeek is offline
Mein Auto: ///M7
Resistor - 138 deg
Driver - 90 deg
Great tests. One thing that really does concern me is the heat generated in the enclosed area. Your tests are out in the open. I would be interested to see heat numbers inside the enclosed lighting fixtures with covers on. I can only presume generated heat may be over 2X-3X that since there is absolutely no ventilation in there.
Options: Executive Package, M-Sport, B&O Sound, LED Lighting, Drivers Assist, Active Cruise. No RWS (Rear Wood Shelf).
Mods: BMS n63tu Tune, PedalBox, H&R Sport Springs, RD Sport Front Lip, Rear Roof & Trunk Spoilers, 20" Forgestar F14 Rims, Akebono Ceramic Brakes, 20% Front/15% Rear Tint, Carbon Fiber Wrap, Smoked Taillights, 760 Exhaust Tips, "Golf Tee" mod, Kidney Grills & Front Vents Painted Gloss Black, Brake Calipers Gloss Black w/BMW Logos, B&W Carbon Fiber Roundels.
Old 06-06-2013, 09:15 PM
TXSTYLE's Avatar
Don't assume....
In fact it could actually be cooler inside the enclosure AWAY from the engine heat.
~Big Marcus
Old 06-06-2013, 09:20 PM
rajeek's Avatar
Mein Auto: ///M7
Originally Posted by TXSTYLE View Post
Don't assume....
~Big Marcus
Marcus,
Huh? His tests above are no where near the engine. The tests are on an open bench. Putting these in the enclosed light housings will increase heat due to lack of dissipation. Adding a hot engine compartment to that again will only elevate that heat level. Not sure how your surmise it would be cooler. Probably going to have to agree to disagree on this one.
Old 06-06-2013, 09:22 PM
ChrisF01's Avatar
ChrisF01 ChrisF01 is offline
Gib mir Feurschutz!
Mein Auto: 2016 750i xDrive
Don't assume....
~Big Marcus
Wouldn't it be the other way around? The engine would get some air through the grille, and the heat would be moving towards the passenger compartment, away from the light housing. Where the enclosed light housing would be like sitting in a car with the windows rolled up?
2016 BMW 750i xDrive M-Sport
Old 06-06-2013, 09:35 PM
coco135's Avatar
coco135 coco135 is offline
Mein Auto: 750i
No since the air circulates. so temp will be constant but still high
Old 06-06-2013, 09:40 PM
rajeek's Avatar
Mein Auto: ///M7
Hot engine air will circulate under the hood, but the light enclosures are essentially sealed when you put that cap on. I am concerned it is an oven in there. Even hot engine air is still quite a bit higher than typical ambient temperatures, thus there is another source of heat to raise temps even further in the enclosure.
Old 06-20-2013, 02:18 PM
1Bob 1Bob is offline
Mein Auto: 2011 BMW 750lxi
Hello to ALL,
I just installed my Mtec angel eye LED's into my 2011 750lxi... I did not use the resistors at first, however, after driving it for a little bit I noticed that the passenger side angel eyes were OUT and the driver side were ON. Also, when I unlock the car before the install my original yellow angel eyes would come ON and remain ON. Then, when the new Mtec LED's were installed they would not come ON when I unlocked the car. In fact, when I turn off my car the angel eyes go OUT with the Mtec LED's.
Does anyone have any input on the subject is this the way it is or did I install the Mtec LED's backwards and upside down? (Just kidding)
By the way they LOOK AMAZING IN THE DAYLIGHT cant wait to see them tonight!!!
P.S. TXSTYLE - Amazing write up... pushed me over the edge to purchase!
Old 06-20-2013, 03:42 PM
TXSTYLE's Avatar
Lightbulb
Originally Posted by 1Bob View Post
Hello to ALL,
Glad to hear that! And you're welcome. Always nice to receive positive feedback from a install writeup or suggestion I post.
My thoughts: Must be the year or software version of your car (soooo much technical stuff in these cars!) which is giving you these different results? *check your settings for Daytime Running Lamps* Mine are set to on.
Here is what happens with mine to this date from the beginning (without resistors just drivers):
I do NOT have/leave my heads set to AUTO. If and when I hit unlock on my fob (or open a door if unlocked) the Eyes do NOT light up! Only after I start the car do they fire up. I figured this is what should happen anyway.
To this very day, neither have gone out while driving because when I pull up somewhere many times in front of glass, they are on! Still get an occasional "parking lamp malfunction error" usually upon cranking but it is very random some days no error at all after several starts!
So I continue to be VERY pleased! The look is quite noticeable. And when I see other F0s with creamy yellow eyes I just
Old 06-20-2013, 03:44 PM
TXSTYLE's Avatar
*edit* Not sure where you purchased... But, I'd still shoot Mtec a email as they are good about responding and helping in my experience. Remember... this is not my first set. I had them on my e65 but they were not as bright as these.
Old 06-22-2013, 06:47 AM
Mtec suggestion
This was the reply that I received from Mtec, also, I agree that they have been very responsive! Which is greatly appreciated!!
I have not tried the solution provided below yet...but, I will this morning and will then provide a follow up to the forum with results...
"Hi,
Did you install the resistors? If so, please unplug the resistors and follow the following steps. Turn on the engine and headlight. Then turn everything off, and LOCK the door with remote. Then you can unlock the door and turn the engine/headlight.
If you do these steps, and you still have problem, please let me know.
Thank you
Thank you for the business!"
Old 06-22-2013, 08:00 AM
asci01's Avatar
asci01 asci01 is offline
Mein Auto: 10 750i
Sounds like these Mtecs don't need the resistors on our cars, just the driver
Old 06-23-2013, 03:20 PM
TXSTYLE's Avatar
"Hi,
Thank you
Glad to hear. Hope that works for you.
Old 07-27-2013, 12:23 AM
giovanni618 giovanni618 is offline
Mein Auto: 2011 750Li XDrive
"Hi,
Thank you
they told me to lock and un lock the three times flash the high beams once and then do a head spin on the hood and then they should be fine
Old 10-31-2013, 02:01 PM
E92-Lighting's Avatar
Mein Auto: 335i
V3 just recently came out.
BMW ACCESSORIES and PARTS
Old 10-31-2013, 03:09 PM
asci01's Avatar
Mein Auto: 10 750i
What are the specs?
Old 10-31-2013, 03:48 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
What's the difference with V3? Any pictures?
2011 750i
Old 06-24-2014, 08:04 AM
Well I brought my car into the dealer so that they can look at a side camera malfunction.
When my service adviser unlocked the car, of course the MTECs don't stay on (which I guess the standard bulbs do). He did it again and only one bulb came on. Now I never thought anything of it. But he is adamant that there is something wrong.
Here is the thing. I could see in his mind that he was trying to tie the bulbs to the camera malfunction. Of course, this is definitely not the case because I had the camera malfunction long before I installed the MTEC bulbs.
Lesson here is that the dealer is always looking for something aftermarket that could get them out of warranty work. Even if has nothing to do with the same system.
Old 06-24-2014, 08:46 AM
TXSTYLE's Avatar
Bingo!
Da fuk outta here with that and fix the real problem!
Bimmer App on HTC-One
