Old 04-27-2013, 04:33 PM
iBeech iBeech is offline
Mein Auto: F20 116i
F20 BMW Live Success!
My car is an F20 M Sport with no extras except for tinted windows and extended dashboard display.
Managed to code up my car this morning to change BMW services to ConnectedDrive and enable BMW Live. I'm was able to connect via my iPhone, sign up, and use all the services successfully!
Only thing is sometimes when I leave the BMW live screen, if I go back I get a grey page. probably missed sone thing while coding. EDIT: after 24hr, this stopped happening, so probably needed a full reset.
I did not VO code the car for this feature. I specifically enabled a couple of features:
HU_ENTRY->3000 HMI->Funktionen->CONNECTED_DRIVE->aktiv
HU_ENTRY->3000 HMI->Funktionen->ONLINE_BROWSER_LIVE->aktiv
you may also need to enable these:
HU_ENTRY->3003 TELEFON_TELEMATIK_ONLINE, 50->Funktionen->DUN_PROFILE->aktiv
HU_ENTRY->3003 TELEFON_TELEMATIK_ONLINE, 50->Funktionen->PAN_PROFILE->aktiv
In order to use this feature, you need a mobile phone with bluetooth, and the ability to use its internet. For example, on my iPhone i must enable the 'Personal Hotspot' functionality in settings. If you cannot see this option, you likely need to pay your carrier for it.
Looking forward to more coding...
ID:	373367   Click image for larger version
ID:	373368   Click image for larger version
Old 04-27-2013, 08:25 PM
theMpower theMpower is offline
Mein Auto: F21 125d
To encode BMW Live I add "6AL" to the list FA and then codified HU_CIC module (or HU_ENTRY).
Old 04-28-2013, 01:25 AM
Mein Auto: F20 116i
Managed to code up my car this morning to change BMW services to ConnectedDrive and enable BMW Live. I'm was able to connect via my iPhone, sign up, and use all the services successfully! Only thing is sometimes when I leave the BMW live screen, if I go back I get a grey page. probably missed sone thing while coding.
Looking forward to more coding... Will post the exact mods I did tomorrow
Attachment 373367
Attachment 373368
What does adding 6AL to the fa list add? I didn't do this?
Old 04-28-2013, 02:11 AM
Mein Auto: F20 116i
Also, how do I add Vo codes?
Old 04-28-2013, 02:34 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
6AL Is the Option Code for BMW Live. Adding it to the VO and VO Coding the Head Unit, and Combox if equipped with one, will make all the required FDL Code changes automatically.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
http://www.bimmerfest.com/forums/att...6&d=1338725691
Old 04-28-2013, 04:01 AM
Mein Auto: F20 116i
I've now read the tutorial and tried the Vo coding. However this makes my ConnectedDrive say BMW Services. So I removed the code and coded manually
I've now got 'Internet' but when loading it it just says loading, and never does anything. However BMW live works fine...
Old 04-28-2013, 06:02 AM
I've now got 'Internet' but when loading it it just says loading, and never does anything. However BMW love works fine...
I never get any BMW Love...
Old 04-28-2013, 11:51 AM
Mein Auto: F20 116i
hahaha
Old 04-29-2013, 02:41 AM
resaran resaran is offline
Mein Auto: bmw f30
Hi,
Can you explain how did you code bmw live because i want to code it too.
Old 04-29-2013, 03:53 AM
Mein Auto: F20 116i
Originally Posted by resaran View Post
Hi,
I have edited the main article with what i coded, and some tips
Old 04-29-2013, 09:09 AM
kon kon is offline
Mein Auto: BMW
"Connected Drive" menu is part of 6NR BMW Apps, having that menu says bmw services or connected drive doesn't affect the functionality. Fdl or VO code is individual preference, but VO code feature tends to stay even when the dealer reprogram the car, so you have less to restore if reprogramming happen at dealer... But this doesn't means it does not have its own downside
Old 04-29-2013, 11:49 AM
Mein Auto: F20 116i
Dealer updated Is a great advantage to VO coding...
Old 04-30-2013, 10:19 AM
vithy vithy is offline
Mein Auto: F30 320i
iBeech, Do you have a combox in your car?
Old 04-30-2013, 10:20 AM
Mein Auto: F20 116i
I do not
Old 04-30-2013, 10:22 AM
Mein Auto: F30 320i
Thanks, I'm going to go try this on mine now. Did you have to enable PAN or DUN on your iDrive?
Old 04-30-2013, 10:23 AM
Mein Auto: F20 116i
Nope. Just make sure your phone can share the Internet
Mein Auto: F20 116i
It's annoying that after spending 25k, an option like this is simply disabled.
Old 04-30-2013, 10:24 AM
Mein Auto: F30 320i
Thanks, Agreed!!!
Old 04-30-2013, 10:44 AM
Mein Auto: F30 320i
I'm assuming this is not country specific correct?
Old 04-30-2013, 11:17 AM
ad78 ad78 is offline
Mein Auto: X5 50i 2011 (dec build)
i added 6AL but i cannot connect to bmw live "service not available. Please try again later"
also i have iphone 5 hotspot activated
Old 04-30-2013, 11:35 PM
Mein Auto: F30 320i
It worked for me. I had to enable DUN and PAN on 3003 to get it to work. It took a good 15min for it to update the live services or to show up under available services. Since I'm in Canada i had to first switch my location to London, England and then changed it to Toronto, Canada. Initially it only showed News and weather, after changing location and back all services remained. Funny thing is my Corporate Blackberry isn't working, however my personal Android device worked without any issues while tethering. I didn't have to enable Hotspot, however had to enable Bluetooth tethering option.
Old 05-01-2013, 01:28 AM
How did you enable DUN and PAN?
Old 05-01-2013, 04:07 AM
Mein Auto: F20 116i
looks like mine were already activated. Here you go
Old 05-01-2013, 05:59 AM
looks like mine has a different structure. here i saw DUN and PAN profile and i put them into active. now im not seeing anything. looks like nothing changed??
