Old 04-27-2013, 03:49 PM
Ron Chapple Ron Chapple is offline
Mein Auto: Z3
dodgy vin # ?
I am trying to source parts for a friend's 1997 Z3 1.9l 5 speed. The compliance plate on the mudguard above the RH front wheel shows vin # LD95573. Real OEM, BMW TIS and vin decoder all register it as invalid. What gives ?
Old 04-27-2013, 04:31 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by Ron Chapple View Post
... 1997 Z3 1.9l 5 speed. The compliance plate on the mudguard above the RH front wheel shows vin # LD95573. Real OEM, BMW TIS and vin decoder all register it as invalid. What gives...
I am not familiar with the terms compliance plate and mudguard, but I have the same car and my VIN is noted on various plates as 4USCH7327VLB77787. Look for something like that. Your car was probably built in Germany rather than the USA, but the number you gave seems too short to be a VIN.
Old 04-28-2013, 10:36 PM
Mein Auto: Z3
The compliance plate I believe is a requirement of the Australian Government to verify that the car complies with their standards for safety, emissions etc. Mudguard = fender. The full vin number is there, I just quoted the last 7 digits as required by realoem and bmw tis. I am wondering why the number is invalid?
Old 04-29-2013, 04:48 AM
Bob2.8 Bob2.8 is offline
Mein Auto: 1997 2.8
Any chance it's an 8 that looks like a 9?
LD85573 comes up as:
" 07/1998 Z3 Z3 1.9 Roadster M44 Europe Right hand drive N
Production Code: CH72 "
Old 04-29-2013, 04:54 AM
vintage42's Avatar
BMW CCA 1405
The compliance plate I believe is a requirement of the Australian Government to verify that the car complies with their standards for safety, emissions etc. ... The full vin number is there, I just quoted the last 7 digits as required by realoem and bmw tis. I am wondering why the number is invalid?
My car has a VIN plate on the dashboard at the windshield, and VIN stickers on the driver door jamb, on the bottom of each door, on the hood, on each front fender, and I did not even look in the trunk.
Do all those factory plates and stickers on your car show the same invalid VIN that is on the Australian compliance sticker? Or is it a case of the Australian sticker alone that has the invalid number? If so, that would be a local error.
Old 04-29-2013, 06:40 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
ALL Z3's were built @ plant Spartanburg in South Carolina, USA.
1999 528iA
2000 Z3 2.3
2003 M5
Old 04-29-2013, 07:17 AM
vintage42's Avatar
BMW CCA 1405
I was confused by seeing statements like...
"Outside of North America, the 1.9 L 4-cylinder was replaced with a 2.0 L straight-6 in 1999... for 2000... The range consisted of the 2.2 L M54B22 (available outside North America)..."
https://en.wikipedia.org/wiki/BMW_Z3_(E36/4)
So Spartanburg built some different engines for the North American and overseas markets, and even right-hand drive cars for the UK.
Old 04-29-2013, 08:21 AM
amancuso's Avatar
Well, see thats actually wrong too. The 1.9L went on till the end of the range in most markets, except for the USA where in 1999MY it was replaced by the 2.3 badged car with a 2.5L engine.
1999 528iA
2000 Z3 2.3
2003 M5
Old 04-29-2013, 03:47 PM
Mein Auto: Z3
vintage 42 - I cannot see any other VIN plates or stickers.
Bob 2.8 - Sounds possible, I will check next time I see the car.
Thank you all.
Old 05-01-2013, 08:46 AM
gmushial gmushial is offline
Mein Auto: 1999 Z3 2.5L
Assuming the "digit" before the L is a V, then is it possible that the "D" (after the L and before the 95) is in fact a "0" (zero)? that would be a valid VIN for a '97 built in Spartanburg SC... the first 7 digits should be 4USCH73.
Old 05-01-2013, 08:57 AM
vintage42's Avatar
BMW CCA 1405
vintage 42 - I cannot see any other VIN plates or stickers...
Are you saying that the only evidence of a VIN number on the whole car is a sticker applied to indicate the car complies with Australian requirements? No factory metal dash tag? No factory stickers on the door jamb, doors, fenders?
Old 05-01-2013, 03:52 PM
Mein Auto: Z3
Bob 2.8 - I think you are correct. The number you suggested lists specifications that match the car.
vintage 42 - I cannot see any other VIN stickers. There is a tyre pressure sticker on the RH door jamb, and under the hood the Australian compliance plate, air con sticker and emission sticker and a little sticker with the paint colour. I looked through the windscreen to the dash, but saw nothing.
Thank you all for your input.
