Old 04-27-2013, 06:41 PM
drbbop drbbop is offline
drbbop
Mein Auto: 2006 650i Vert
Direct drive
Getting messages about direct drive and take off assistance disabled .
Anyone with similar problems, 2006 650 vert with 38,000 and no modes, auto transfer
Old 04-27-2013, 09:33 PM
Yorgi's Avatar
Yorgi Yorgi is offline
I have not heard of a message with that wording. Take a pic of the iDrive display with your cell phone next time the error pops up and give us the exact wording.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 04-28-2013, 09:01 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
Do you mean Dynamic Drive?
Check that your battery is fully charged. Make sure your Power Steering fluid is not low, the Dynamic Drive system uses the same fluid system as the Power Steering.
I had that error also a while back and it turned out to be my Steering Angle Sensor. This is located in the steering column.
Old 04-29-2013, 08:45 AM
drbbop
Was the drive control system and the start off assistance inactive warning that I got. I am trying to locate some CFS11 fluid, but is not sold in the local parts stores here such as advance auto and others. Thanks
Old 04-29-2013, 09:12 AM
Check with any dealer that deals with German cars, I know that Porsche uses the Pentosin. Maybe call VW dealer if you don't have a BMW one near?
Old 04-29-2013, 10:08 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
NAPA Auto also carries it.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 04-29-2013, 11:38 AM
drbbop
Power steering looks low.
Old 04-29-2013, 06:05 PM
Yorgi's Avatar
The errors basically indicate your DSC is deactivated which is normally a result of a bad sensor.
The most likely cause is steering angle sensor or sometimes low power steering fluid can cause it due to a dynamic drive system error.
You could also have a bad steering sensor control module or a bad wheel speed sensor.
'04 M3 - track
Old 05-04-2013, 06:07 PM
drbbop
Yogi changed a rear rim 3months ago, with BMW rim, but had no problem until I started playing with the sport setting. I am no coder so how to check sensor control module vs wheel sensor? Car has 38,800 it.
Old 05-04-2013, 06:19 PM
drbbop
Sitting in the car, clear code, start motor turn steering wheel slightly drive control warning pops up
Old 05-06-2013, 07:55 PM
Yorgi's Avatar
Sounds like the steering angle sensor. You will have to bring the car in to a shop to confirm.
'04 M3 - track
Old 05-06-2013, 08:01 PM
HerbP HerbP is offline
+1
Old 05-07-2013, 08:43 PM
drbbop
Thanks alt is putting out and battery is accepting but I did notice corrision on positve post
