Old 04-28-2013, 11:34 AM
TL2E90's Avatar
TL2E90 TL2E90 is offline
Mein Auto: 2009 BMW 750i
Coding
Guys,
my car is F01 MY 05/2009 and I successfully coded the following functions:
-TAILGATE ON/OFF REMOTE CONTROL
-TIRE PRESSURE MONITOR
-LEGAL DISCLAIMER ON IDRIVE (BOTH NAVI AND CAMERAS)
-NAVI FUEL STOP PROPOSAL (DID NOT TEST IT YET)
-HUD TURN SIGNAL
-HUD PLAYLIST
-HUD INCOMING CALLS
-L7_SURROUND CONFIGURATION
-FOLDING MIRRORS REMOTELY (PRESS REMOTE FOR 2 SEC OTHERWISE NORMAL OPERATION)
This forum rocks! Thank you very much for your help! SPECIAL THANKS TO SHAWN!!!!
Old 04-28-2013, 03:18 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Originally Posted by TL2E90 View Post
Guys,
-HUD TURN SIGNAL
-HUD PLAYLIST
-HUD INCOMING CALLS
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 04-28-2013, 05:50 PM
TL2E90's Avatar
Tire pressure and temperature monitor actually doesn't work, it shows dashes only.
Old 04-28-2013, 05:55 PM
Do you have Option Code 2VB?
If so, and it does not work, you probably have Old Style TPMS Valve Stems / Sensors, and they do not work for some reason.
Old 04-28-2013, 06:50 PM
TL2E90's Avatar
I have FTM. It is not going to work. Anyone had success retrofitting TPMS
Old 04-28-2013, 08:32 PM
Sad but true. FTM TPMS is simply Rotational Speed based, with no actual sensors.
I have not heard of anyone retrofitting RDC TMPS (2VB).
Old 04-29-2013, 05:24 AM
TL2E90's Avatar
Do you guys know what NAVI_ROAD_PREVIEW and JUNCTION_VIEW_HUD are for (HU_CIC)?
Old 04-29-2013, 08:11 AM
I only know what the comments state:
NAVI_ROAD_PREVIEW = Road preview is possible or not
JUNCTION_VIEW_HUD = 3D exits HUD
I tested NAVI_ROAD_PREVIEW, and it had no noticeable effect.
I never tested JUNCTION_VIEW_HUD as I do not have HUD in my car. I am sure though many others with HUD have tested it, and no one has reported it as doing anything.
Old 04-29-2013, 08:18 AM
TL2E90's Avatar
Well, I did set them both to Aktive and notice no difference. I suspect that some of the seetings require some pre-settings (within same module or even other modules) to make them work.
Old 04-29-2013, 08:38 AM
TL2E90's Avatar
Is there a way to enable Traffic service on our Navi?
Old 04-29-2013, 09:02 AM
You can try adding 6UH to your VO, and VO Coding HU_CIC.
Old 04-30-2013, 06:06 PM
TL2E90's Avatar
How can I add 6UH to my VO?
Old 04-30-2013, 06:57 PM
Change VO:
http://www.bimmerfest.com/forums/att...6&d=1338725691
VO Code:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Old 04-30-2013, 08:50 PM
TL2E90's Avatar
I followed the exact procedure but Edit button is always grayed out when I select FA. Any suggestions?
Old 04-30-2013, 08:51 PM
Hit Save first, and then you can hit Edit.
Old 04-30-2013, 09:23 PM
TL2E90's Avatar
THANKS!
Old 04-30-2013, 09:33 PM
TL2E90's Avatar
6UH is not on the list. Can I manually add it?
Old 04-30-2013, 10:35 PM
Yes. You would add 6UH under SALAPA-Element, save the VO, load the VO, and VO Code HU_CIC.
Old 05-02-2013, 07:28 PM
TL2E90's Avatar
Shawn, do you know of any way to increase the brightness of orange light for buttons? The thumbwheel adjuster is at max already but I would like to increase the brightness a tad more. Thanks
Old 05-02-2013, 11:27 PM
Sorry, but I don't know on that one.
