Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 04-28-2013, 04:29 PM
Z4-Life Z4-Life is offline
OFP
Mein Auto: 2005 Z4 2.5i
Magnetic Drain Plugs
I am planning on draining and replacing my Bimmer's oil, tranny and diff fluids and then changing out the stock drain plugs for magnetic ones.
I've seen BavAuto carries magnetic drain plugs for oil, tranny, and diff for about 29.95 - 34.95 a piece made by Dimple.
http://www.bavauto.com/fland.asp?par...e=SS%20M12X1.5
ECS Tuning and Tuner Motorsports also carry oil magnetic oil drain plugs at 9.95 - 12.95 each.
http://www.ecstuning.com/BMW-Z4-2.5i...Plug/ES251839/
http://www.turnermotorsport.com/show...-for-most-bmws
Can any one who has used these or any other magnetic drain plug comment on the quality and performance of these plugs. I was wondering what the differences are.
(I've read elsewhere BavAuto can be overpriced at time)
***I posted this on Zpost put didn't get too much response/visibility, so I figured I would repost on a larger forum. I apologize for any inconvenience.
Old 04-29-2013, 07:36 AM
neelkc12 neelkc12 is offline
Mein Auto: X3
May be outdated but here is a relevant thread
http://www.e90post.com/forums/showthread.php?t=748215
Old 06-11-2013, 04:11 PM
rsutoratosu rsutoratosu is offline
Mein Auto: Z4
sorry to chime in so late, i got it for both diff and oil drain. I love it.. its so strong that I can't get it into the drain hole correctly, it keeps drawing itself to any metal piece near the drain hole. But once its in, its good. no phun intended
i have the bav auto one
