Old 04-28-2013, 04:19 PM
Nittenyadhav's Avatar
Nittenyadhav Nittenyadhav is offline
Mein Auto: BMW F10 520d 2016
FEM_Body error....need help
Hi guys,
Just got my car this Friday and did setup E-Sys as per the step by step instruction and I backed-up the original CAF files. Every CAF file was backed-up except FEM_BODY. Whenever I try to read it its giving me error:
FEM_BODY [40]
readCPS 0.k
cafd_00000794-004_228_010 Fehler:
File for "cafd_00000794_228_010" not found! [C012].
Can you please let me know how I can fix this.
While you reading this Could I please also ask how I can get these options for my car?
1: Show Sports meter in iDrive (I dont have Navigation so its normal iDrive screen 6.5" I think)
2: Fold and unfold the mirrors with remote lock and unlock buttons.
3: Any way I can get the audio file names in iDrive and instrument cluster to scroll?
4: Auto Start/Stop function to start in the last used setting
5: Unlocks doors when engine is stopped only when start/stop button is pushed.
6: Allows single pull to open all doors.
7: Enable the gear shift indicator got all 4 driving options (ECO PRO, COMFORT, Sports & Sports+)
All help will be very much appreciated.
BMW 520D M Sports Plus F10
Old 04-28-2013, 11:20 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by Nittenyadhav View Post
Hi guys,
FEM_BODY [40] [F137962]
readCPS 0.k
cafd_00000794_228_010 is not in any PSdZData release though 49.2. I suspect your car came from the factory with something even newer, like 49.3. I am not sure though if ISTA/P 2.49.3 has even been pushed to the dealers yet, but I will find out tomorrow. If it has, then you will need a copy of it to code your FEM_BODY module.
As for your coding specifics:
1) Only possible with Nav Professional, which your car does not have.
2) Check F30 Coding Cheat Sheet for Coding
3) Not possible as far as I know.
4) Check F30 Coding Cheat Sheet for Coding
5) Not sure I understand. How is it unlocking now if not when Start/Stop is pushed?
6) Check F30 Coding Cheat Sheet for Coding
7) Only possible with 6MT (6 Speed Manual Transmission), which your car does not have.
F30 Cheat Sheet:
https://docs.google.com/spreadsheet/...Ia3ZmbUE#gid=0
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 04-29-2013, 03:09 AM
Thanks for looking into this and for F30 Cheat Sheet Shawn. I'll wait for you confirmation on latest PSdZData.
Old 04-30-2013, 12:46 AM
Hi Shawn did you get any luck with 49.3 PSdZData?
Old 04-30-2013, 10:41 AM
Sorry, but not yet.
First we need to confirm the existence of a new ISTA/P, presumably 2.49.3.
Check the I-Level of your car, and advise what it shows for I-Step Current:
http://www.f30post.com/forums/showpo...postcount=1403
If it is something newer than F020_13_03_503, like F020_13_03_504, then we have a new ISTA/P version.
If that is the case, then I will find out if BMW AG has pushed this new version out to the dealerships yet, and if so, I will get a copy.
Old 04-30-2013, 02:02 PM
Thanks Shawn, I checked it and I level of my car is F020_13_03_503 (please see the image attached). Please let me know what you suggest I can do to fix this issue?
Old 04-30-2013, 04:35 PM
Well, I was able to confirm earlier today that ISTA/P 2.49.3 does in fact exists, and I am pretty sure it is what you car has on it.
While your I-Level is F020-13-03-503, which is ISTA/P 2.49.2, I think we are going to see that for the F20, ISTA/P 2.49.3 is also the same I-Level, as it is often the case where the I-Level does not change with ISTA/P versions.
So, now we need to wait until the 49.3 PSdZData is available, which should not take more than a few days, and I expect cafd_00000794-004_228_010 to be added in it.
Old 04-30-2013, 10:42 PM
I can confirm now that all Fxx chassis I-Levels remained unchanged at Fxx-13-03-503 in ISTA/P 2.49.3, and that cafd_00000794.caf.004_228_010 is 1 of 6 new CAFD's added in 49.3.
PM sent.
Old 05-01-2013, 12:26 AM
Thanks for look into this Shawn, much appreciated. I'll add the new CAFD file and report back.
Old 05-01-2013, 01:03 PM
hi Shawn,
thanks for that file it working and reading the FEM_Body CAFD file, however now when I'm trying to edit any of the cafd file I'm getting this error (please see attached image). I do have the code away file and I did mapped it in settings.
Any help will be appreciated Shawn. Thanks a mill
Old 05-01-2013, 02:00 PM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
hi Shawn,
You can't use the old 3.18.4 Code Away token to code an F30 with 2.49.0 or later. You need 3.22.5, a set of patches, and a new token. PM Shawn for details.
Old 05-01-2013, 02:30 PM
thanks FrogmanF30, I actually have E-Sys 3.22.5 and psdzdata 49.1. I think I dont have code away for 3.22.5. may be Shawn can help.
Old 05-01-2013, 02:38 PM
thanks FrogmanF30, I actually have E-Sys 3.22.5 and psdzdata 49.1. I think I don't have code away for 3.22.5. may be Shawn can help.
Look at the picture you just posted. E-Sys Options is still pointing to the old Code Away.EST file. You need to change it to point to your new .EST file.
The two patched .jar files need to be renamed and put in their proper location too if you have not done so.
Old 05-01-2013, 03:19 PM
Thanks Shawn, could you please let me know more about these .jar files? where I can locate them, what new name I need to give them and where I need to place them?
That other part is also done I'm waiting on mail reply now
Old 05-01-2013, 03:38 PM
They will come with the "other part", with instructions as to which two folders they go in. You need to remove PATCHED from the file names first.
Old 05-03-2013, 12:19 AM
Hi Shawn,
Just to update you all is working fine now with E-Sys after purchasing the token. I've tried 1 or 2 codes and they worked great. Thanks for all of you and especially you Shawn for helping me out. Today I'm taking my car for Boot lid issue to dealer and once back I'll try few other codes what I wanted to do. If any issues I may have I'll seek your help. Thanks agian.
Old 05-03-2013, 09:06 AM
Hi Shawn,
Old 05-03-2013, 10:06 AM
Hi Shawn, You know if there is a way to get the PSI reading for Tyre pressure in my iDrive for F30?
Old 05-03-2013, 10:08 AM
I am pretty sure you have FTMS, not TPMS, and FTMS has no actual pessure / temp sensors as it works only a tire rotational speed.
If you do not have Option 2VB, you do not have the proper TPMS hardware.
Old 05-03-2013, 10:38 AM
Ahh thanks Shawn I checked and I dont have 2VB in FA so I cant have this.
Old 05-04-2013, 10:31 AM
Hi Shawn, could you please help me out with connection issue Im getting in E-Sys? Today I went in car to do some coding and for some reason I'm not getting connection (please see the image). I can see the yellow mark on network connection but when I go to connect its ZGW I'm getting blank screen. Everything was working fine before. Do you know what causing this and how I can resolve it?
Old 05-04-2013, 12:18 PM
Assuming it was working fine yesterday, and you have made no changes whatsoever with E-Sys Configuration or Data files, I suspect a bad cable connection or E-Sys or your PC Lan Port is jammed up somehow. I would reboot PC, make a fresh ENET Connection to the car, and make sure the cable is making good contact on both the OBD II and Ethernet sides and try again.
Old 03-28-2015, 02:38 PM
Rer67 Rer67 is offline
Mein Auto: 320
Hello....
FEM_BODY [40] yyyyyyy
readCPS 0.k
cafd_ffffffff_255_255_255 Fehler:
File for "cafd_fffffff_255_255_255" not found! [C012].
See attached file
Old 03-28-2015, 02:42 PM
Originally Posted by Rer67 View Post
Hello....
readCPS 0.k
See attached file
You corrupted the CAFD, likely due to power loss during coding of FEM.
You must inject new CAFD into ECU and VO Code it.
Old 03-29-2015, 01:16 AM
Mein Auto: 320
Thanks for answer...
i would code the BLINKZYKLEM_ANZAHL_TIPP to "werte=04". It comme also from that coding !!.... the coding say ERROR ...
How inject new CAFD into ECU and VO Code it
Can you help me ?
thanks
