Old 04-28-2013, 07:03 PM
damccull damccull is offline
Mein Auto: 2008 328i
Brake pads without clips
Hello internet friends. I have a 2008 328i on which I must change the front brakes. When I got pads from auto zone, both the inner and outer pads have clips on the back, but my outside pads currently on the vehicle don't have any. The pads that go on the cylinder have three prongs that hold it into the cylinder. The other side of the caliper doesn't have any place for clips to connect to.
Where do I find the right pads outside of a BMW dealership?
Thanks,
damccull
Sent from my Galaxy Nexus using BimmerApp mobile app
Old 04-28-2013, 07:47 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Those pads are correct but obsolete. The pad set with clips on the outer pads is an older part that has been superseded by the clip-free design. Per the BMW TIS, either is acceptable.
Edit: Are the pads identical except for the clip? You may just need to bend the clip slightly to get it to fit in the caliper. If there are any other differences in the pads, or they will not fit at all, return them and stick to genuine BMW parts. If your local dealer has unreasonable prices, try an online vendor such as Tischer BMW or Bavarian Autosport.
Further edit: Forget what I said about the obsolete/superseded parts--I forgot for a moment the 335i has different brakes from the 328i. Sorry for any confusion...basically, save yourself the aggravation and go to a vendor that specializes in European cars.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 04-28-2013, 07:59 PM
Re: Brake pads without clips
The pads I bought are these (I have since returned them) http://m.autozone.com/autozone-mobil...ko29?id=823466
The inner pad has the three prong clip and fits perfectly. The outer one has a clip that's on the back. My caliper has nowhere for that clip to go so it's in the way. Other than the clip I can't see any differences between that and my old pads.
Old 04-29-2013, 01:36 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
My OEM replacement pads on the front didn't have the clips either. It is probably for the assembly line. Keeps them from falling off and they move down the line.
Old 04-29-2013, 01:52 PM
Problem is the clips are permanently riveted on. They aren't detachable. The BMW dealership service department told me the correct brakes don't have clips either.
