Old 04-29-2013, 12:59 AM
Vikont Vikont is offline
Mein Auto: Z3
Exclamation Idle runs high itself on turn
Hi everybody,
I got Z3 1997, M44 engine and problem persists since I bought it. When in 4th and 5th gear on around 3000rpm car keeps running even though gas pedal is released (feels like cruise control). Stays on 3000rpm and then you can feel 2 engine shakes (very mild) before rpm falls down normally.
Other concerning thing is that when making turn idle lunches up like crazy (up to 5000-6000rpm). This happens always, any gear, even i neutral..
Idle is stable and normal when starting the engine, no change when a/c, lights are on.
Throttle body changed, idle control valve cleaned, computer test gives nothing and car never had cruise control
I learned how to drive it and adopted to that behaviour But my wife is gonna start driving it soon and theres my concern
Thank You
Old 04-29-2013, 07:27 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by Vikont View Post
... Z3 1997, M44 engine... When in 4th and 5th gear on around 3000rpm car keeps running even though gas pedal is released (feels like cruise control). Stays on 3000rpm and then you can feel 2 engine shakes (very mild) before rpm falls down normally. Other concerning thing is that when making turn idle lurches up... to 5000-6000rpm). This happens always, any gear, even in neutral... Idle is stable and normal when starting the engine, no change when a/c, lights are on. Throttle body changed, idle control valve cleaned, computer test gives nothing and car never had cruise control...
Perhaps the throttle cable is sticking or frayed or needs adjustment. Or the pivot shaft needs a little oil.
Old 04-29-2013, 10:30 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Check your motor mounts. The only thing I can think of is if one of your motor mounts was broke and the engine is moving and pulling on the throttle cable or a broken trans mount. This is weird. Good luck. Please keep us posted.
Old 04-29-2013, 12:31 PM
Mein Auto: Z3
Throttle cable checked, no probs with it. It's weird it's get stuck only in 4th and 5th around 3000rpm and above (2nd and 3rd runs normally) and on turns even in neutral. So i guess if it's cable it will stuck always when pulled above 3000. Still on turns if i really slow it (below 20km/h), it drops and runs normally.
Thnks for reply
Old 04-29-2013, 01:04 PM
Maybe that idle control valve is shot ?
Old 10-15-2014, 04:47 AM
Mein Auto: Z3
Problem Solved
After 2 years of dealing with it (throttle body and idle control valve changed with no success) recently finally fixed.. or discovered new problem, however car runs fine. All I had to do is to switch off ASC. I did not realise any change in my traction or braking. Idle is perfect, drops normally like never before.
I guess this may pull out other problem.. but no error codes found when my car was taken to the bmw service.
