E36 (1991 - 1999)
Old 04-29-2013, 08:30 PM
7ate9 7ate9 is offline
Mein Auto: E46 330I
Unhappy Question on E36 Vibration During Acceleration
Car: 1995 318IS
Mileage: 182K
Transmission: 5SPD
Issue: When I accelerate and I hit roughly 3-4K RPM I get a vibration under the car (center console area + rear wheels). It sounds like something is knocking, and its jumpy .
If I slow down, this vibration lessens or goes away. It does not matter how short or long I've been driving before this vibration occurs.
Possible answers: I did read up on some forums. I see that it may be issues with the CV Joint/Axle/Boot. Either replacement or just need to remove old grease and add fresh new grease. Also read that it may possibly be a failing or busted: "U joint," differential, engine/tranny mount, drive shaft, guibo(big maybe), center bearing, half shaft, wheel bearing, sway bar being loose.. etc
I need your help. Please
*** Yes I am sure its RPM/HIGH RPM related. Its whenever I accelerate. I could be in 3rd gear going up a hill OR 4th gear on highway going up a slope OR even flat ground going in 2nd gear over 4K. Once I give it gas maybe pass 3-4K it vibrates in the center console area, and rear of car. ***
VIDEOS: BEST EXAMPLE IS VIDEO 4 OF 4
http://www.youtube.com/user/OMGvst/videos
Old 04-29-2013, 10:21 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
Sounds like your center support bearing or guibo inspect both. Any cracks on guibo are signs that it needs to be replaced. But I bet its your csb.
Old 04-30-2013, 03:45 PM
Marclar Marclar is offline
driving my marclar
Mein Auto: 97 E36 328, 01 E38 Sport
I would bet on the driveshaft (the center bearing is worn out). This issue slowly escalates as the wear worsens quickly. In such a case I usually buy a whole new driveshaft and replace it. A few bucks more, but makes the work so much easier when you dont have to deal with the bearing replacement.
Old 05-01-2013, 06:13 AM
r2hoog1 r2hoog1 is offline
Mein Auto: 1998 BMW 328i e36
I had a vibration in the rear that worsened over time. It would start up around 25mph and get more severe the faster I went. If I let off the gas, it smoothed out.
I thought it might be the flex disc or center support bearing, but it ended up being a bad u-joint. (not repairable by BMW design - driveshaft needs to be replaced) My mechanic found me a driveshaft at a junkyard for $150 and charged me about 3 hours labor to put it on. Nice and smooth and quiet now! This was just yesterday.
Check the u-joints.
r2hoog1 - '98 328i
Old 05-01-2013, 07:16 AM
Hectorml07's Avatar
WYKDBMR
Check the u-joints.
I found my driveshaft at a junk yard for like $40ishh bucks . I guess your mechanic charged you about $110 bucks for removal which only takes about half an hour or less. It's good to be handy with tools.
Sent from my PC36100 using Bimmer App
Old 05-01-2013, 07:25 AM
That was the junkyard charge, I know because I paid them. $150 is still way better than $350 for a rebuilt driveshaft on line.
The point being, look for a used driveshaft.
r2hoog1 - '98 328i
Old 05-01-2013, 07:37 AM
Hectorml07's Avatar
WYKDBMR
Was it already taken off and you just went to pick it up? Or did your mechanic take it off? If not that is a lot for a used driveshaft.
Old 05-01-2013, 07:46 AM
It was already taken off by the junkyard. And, it was the only one we found in my area.
r2hoog1 - '98 328i
Old 05-01-2013, 09:21 AM
Hectorml07's Avatar
WYKDBMR
Oh ok, yea that makes more sense. Usually wrecking yards that sell you parts that are taken off already will charge you a lot more.
Old 05-01-2013, 10:40 AM
ECSTuning's Avatar
Instructor of the Stig™
I'd start by inspecting the Guibo, a good one is going to resemble the image below, a bad one is going to have stress cracks, missing sections, or look like it's made of string. The guibo will be BMW part number 26111227410, I have it available HERE.
Also while your under the car inspect the center support. It shouldn't have any grease leaking form it, or show signs of deterioration. The center support will be BMW part number 26121226731, I have it available HERE.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 05-01-2013, 05:23 PM
Mein Auto: E46 330I
Thanks everyone!
Old 05-02-2013, 05:07 AM
Originally Posted by 7ate9 View Post
Thanks everyone!
Good luck - Let us know the result!
r2hoog1 - '98 328i
Old 05-02-2013, 07:49 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
It's Giubo.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 05-10-2013, 03:56 PM
Mein Auto: E46 330I
---Houston we had a problem... or problems---
I was driving, and *bam* shifter wasn't connecting to gears. Pulled over on the highway and got my 4-banger to the garage. Along with my vibration, they were both fix and now I can drive regularly. *RECEIPT SAYS WHAT MY ISSUE WAS WITH VIBRATION, SO NOW OTHERS WITH THE SAME VIBRATION CAN ZONE IN WHATS MAYBE THEIR ISSUE.
Here's he receipt:
Old 05-10-2013, 04:20 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
Looks like "bam" was when the front end of the driveshaft, freed from the guibo, smashed the shift link bracket. Oh well, if you had replaced the guibo and center bearing before complete failure, you would only have saved the $28 for the bracket (and the cost of the tow). Glad you're all fixed up.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 05-10-2013, 04:39 PM
Mein Auto: E46 330I
I was going to fix it the thursday afternoon/friday, it happened on thursday morning on my way to class. *shrugs* oh well. thanks
Old 05-13-2013, 08:25 AM
petriej's Avatar
It's Giubo.
GGC BMW CCA #443004
Join the BMW CCA!
e36 vibration
