Old 04-30-2013, 10:02 AM
penofin penofin is offline
Mein Auto: 2011 550xi
Unhappy meisterschaft ev control exhaust
my ev control on my 2011 550xi stopped working after 7 months, called the company and they said the warranty is only good for 6 months considering i have driven the car only 10 times from dec to middle of april. The local dealer (next mod) can't help with warranty, paid 4k for the exhaust -- sounds good but bad quality motor control. anyone looking to buy this exhaust skip the ev control. It will cost u $600 to get the new unit, it's costly if they r build to last for 6 months.
Old 04-30-2013, 10:16 AM
MoldCAD's Avatar
MoldCAD MoldCAD is offline
Mein Auto: M235i
No offense, but things like this just need to be used - more often than 10 times in 4 months.
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive
AWD hooligan: 2015 Golf R mk7 DSG
RWD true bimmer: 2015 M235i 8AT fully loaded, with LSD
Old 04-30-2013, 11:11 AM
The Yeti The Yeti is offline
Mein Auto: 2013 550i
how much?
Old 04-30-2013, 01:29 PM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
BS. I would be pissed. Keep complaining. The OEM should step up and take care of the repair. Else I would be doing exactly what you are doing, posting everywhere about your experience.
Good Luck.
Old 04-30-2013, 03:26 PM
paid 4 grand and $500 for installation. Do u guys think i got ripped off. Could it be that the controls r not made for canadian winter with all the road salt that corrodes the exposed parts. Love the sound but sometimes u take the family out it's nice to mute the sound for the kids. To no avail i guess i have to give up the fight for the warranty, cause they will do nothing about it. Hope no one has to go the same experience as me. Will keep my eyes out for new exhaust.
Old 04-30-2013, 03:31 PM
did i pay too much 4 grand plus 500 for installation.
Old 04-30-2013, 03:52 PM
First of all, $4000 seems to be the going rate for the EV exhaust. $500 for install is higher than an average exhaust but keeping in mind that the installer had to mount and wire a switch for the EV control, maybe a bit high, but doesn't strike me as a total rip off.
Next to real problem, do you know why the EV portion isn't working? I assume the installer put this switch on a fuse? Have you checked to see if you have a blown fuse. If not, what component failed? The install seems to be a switch, some wires, and a couple of solenoid valves. What is the OEM sending you that could possibly cost $600????
Old 04-30-2013, 04:03 PM
definitely not the fuse cause i can hear the motor trying to turn n than stop, the installer said the valve is seized. he mention taking out the back portion and manually try to close off the valves or leave it slightly open to tone down the noise, do u think it might work?
Old 04-30-2013, 04:05 PM
If you are giving up on warranty, sure take it apart and see if you can free up the valve. What do you have to loose?
Old 04-30-2013, 04:25 PM
the warranty is already over, i will let u know in a few days after it's done.
Old 04-30-2013, 04:38 PM
Can you access the moving valve through the exhaust tip. Give it a little help maybe?
Old 05-01-2013, 02:08 AM
MoldCAD's Avatar
Mein Auto: M235i
Good Luck.
I never said the OP shouldn't try to get it sorted out - but with a mechanism as exposed to corrosion/deposit as anything exhaust, "use it more often" is probably what he will be told.
Old 05-03-2013, 02:35 PM
the company has agreed to replace the parts, all i have to do is send them back the parts but pay for shipping--- sounds fair
Old 05-03-2013, 02:42 PM
good deal. Sounds more than fair.
Old 11-07-2013, 05:29 PM
ausdude's Avatar
ausdude ausdude is offline
Mein Auto: 2013 BMW 550i M-Sport
Has your exhaust continued to work? Anymore problems?
Untitled[/url] 550i M Sport|300|LCSW|4MR|2TB|704|760|PDC|ZEC|6F2|ZDA|5AD |416|494|Dinan Stage 2|CF Spoiler,MirrorCaps&Splitter|M Performance Diffuser|Front Reflector Delete|Black Grilles|Rear Fog Lights|Euro Side Mirrors&Tail Lights|M5 Front & M550D Rear Sway Bars|20" HB04|Roof Wrapped|Coded|CCA member
