The X5 SAV Forum
Old 04-30-2013, 01:28 PM
ebrockman ebrockman is offline
Mein Auto: 2005 X5 (e53)
Help! No resistance in brake pedal
I was driving around town today when all the sudden when a "Brake fluid low" message displayed on my dash. I still had braking power, but I noticed that the pedal when depressed would slowly drift to the floor. I got home safely, but by then I've noticed there's no resistance or braking power until it gets all the way to the floor, then I will get braking power. The fluid reservoir was about 2 inches below the "low" line. I've looked, but haven't readily found an obvious place brake fluid is leaking in my lines. To be honest, I've never really checked the brake fluid level in a couple years (yes I deserve a flogging for that) so I don't know if the low fluid level is new or a chronic issue. Do I most likely have a leak, or is the low fluid level misleading and its actually a failed master cylinder? Could someone please weigh in on the most likely issue? Thanks!!
Old 04-30-2013, 02:48 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Sounds like a definite leak. Could be anywhere in the entire system. Don't worry about that neglect, no one will haggle you. That's the most commonly neglected car system. BTW my '00 Jetta is a manual and went twelve years before its first pads and rotor change.
If you've never changed the fluid, moisture and contaminants could harm the seals in the master cylinder and recirculate without a leak noticeable.
Old 04-30-2013, 03:36 PM
Thanks, I think you're exactly right. I took down the shroud under the drivers side and it looks like both right and left lines are in horrible shape. Not sure which is the culprit, but they both need to be changed. Thanks!
Old 05-01-2013, 02:05 PM
TechWrench TechWrench is offline
Mein Auto: '99 540i, '02 X5 3.0i
Unfortunately, the E53's have a known rust issue with the brake lines and connectors. I already answered your post in the 'other' forum. Good Luck.
