Valve stem seals done for $2500! - Bimmerfest - BMW Forums
Closed Thread
Old 04-30-2013, 04:23 PM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
For those who don't know me.... I'm a BMW master tech located in Long Island, NY who has helped out many forum members here in the past (just do a search and you'll find me). I've been seeing many posts about the common valve stem seal issue with the N62 and N62TU engine. Symptoms include excessive oil consumption and severe smoking from the tail pipe. I'm offering to complete the repair for $2500 total (parts and labor). This includes both bank valve cover gasket sets and the updated valve stem seals of course. I would need 2 full days to complete the repair, I'm available on weekends (I work at the dealer during the week). Most dealers charge anywhere from $8,000 to $12,000 to have this done, so here's your chance to save a ton of cash! I've had someone drive over 12 hrs to meet me and to have the repair done, it was well worth it for that customer. You guys can post here or PM me. I'm also a forum regional sponsor, so my contact info is located in the section of the forum. Thanks!
Old 04-30-2013, 07:00 PM
drbbop drbbop is offline
drbbop
Mein Auto: 2006 650i Vert
Hope I never have to but thanks for the generous offer
Old 04-30-2013, 07:24 PM
HerbP HerbP is online now
For some that don't know, this is a very good price. Since you are a BMW Tech, what is your take on the secondary air passages that become blocked? Is there a repair that you can perform while you have the valve covers off. I know that you will probably have to remove the intake, but do you have a repair procedure that can be done without removing the heads? This is becoming a fairly common problem, so what are your thoughts? Are these 2 failures due to extended oil changes, or due to cheap & non-ethanol fuel? I am also surprised that your dealership allows you to do repairs on the side!
I am not trying to put you on the spot, but I would like to hear your thoughts?
Old 04-30-2013, 08:40 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
I hope that I do not have to do this job, but it would be better if you were here on the West coast.
Once a 6'er, always a 6'er.
Old 05-01-2013, 01:50 AM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
Never heard of this problem. Please elaborate......
Old 05-01-2013, 06:10 AM
Past Sponsor
Mein Auto: X3
The secondary air issue is a separate repair. Typically we remove the heads to clean out every last bit of carbon. I'm currently working on a more cost effective repair that does not require removal of the heads. The cause for the blockage is due to the exhaust valve stem seals leaking oil down the back if the valve and carbonizing when it hits the relatively cooler air providing by the secondary air pump. I don't think the extended oil interval is the cause of the seal failure, I've done them on cars with as little as 45k miles.
Old 05-01-2013, 08:45 AM
telecop38 telecop38 is online now
Mein Auto: 645Ci
YESSSSSS!!!!!! The lord has anwser my prayers!!! I've been having this problem for 1.5 years!!
Old 05-01-2013, 02:02 PM
A lot of BMW's have valve stem failure after 80k miles or later. When the valve seals get hard, oil starts to seep passed the seals. When this happens, the engine will start to smoke after stopping at a stop light. In my experience engines that have been abused by a lack of maintenance , typically will have the seals harden from oxidation of the oil. This can happen in any manufacturers engines, but a BMW cost a lot more to repair. You can see a lot of post on the 7 Series forum.
The clogged air passages in the heads, are another high ticket item to repair. Finding a way to clean the passages without removing the heads, would be a huge cost savings. I have seen where a couple of people on the 7 series have been able to soak the passages by removing the intake, & getting them to clear without removing the heads. I think that there is a lot of trial & error on this repair. A proven method would be a good find! I hope I never get to experience either of these problems
Old 05-04-2013, 07:06 AM
Past Sponsor
Mein Auto: X3
Bump for you guys
Old 05-05-2013, 04:54 AM
Past Sponsor
Mein Auto: X3
Here's a close up pic of an old seal next to a new one, the difference is pretty clear
Old 05-11-2013, 01:23 PM
Past Sponsor
Mein Auto: X3
bump
Old 05-14-2013, 08:30 PM
mike43lake mike43lake is offline
Mein Auto: 650i
For future reference, do you do all kinds of repairs, brakes,oil changes, tune-ups, etc.? Where in L.I. are you located?
Old 05-15-2013, 04:05 AM
Past Sponsor
Mein Auto: X3
Yes, I do everything. I'm located in Nassau county, valley stream area
Old 05-15-2013, 04:06 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
I live in ky and would drive up for that price!
Old 05-15-2013, 06:41 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Nice to know. I'm in NY and know a lot of BMW owners that would welcome a really good shop. I know a couple of folks out in Queens that take their cars to a shop out there as well. Might be your spot. PM me.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 05-15-2013, 07:41 AM
Past Sponsor
Mein Auto: X3
PM sent
Old 05-15-2013, 08:32 AM
carrazco650i carrazco650i is offline
BMW Rookie
Mein Auto: 650i
BMWOEM1 would you recommend an engine flush or fuel system cleaner, to avoid this repair or after the repair is done.
2010 BMW 650i, Lowered Eibach, 255/45R19 Front, 285/35R19 Rear. Resonator & H box delete, and X pipe installed upstream.
Old 05-15-2013, 08:58 AM
Mein Auto: 650i
Good to know. I'm up in Dutchess County. But I am down at Long Beach a lot. I will look you up when I need service. Thanks.
Old 05-15-2013, 02:17 PM
Past Sponsor
Mein Auto: X3
A flush or cleaner would do nothing to prevent this problem. From my experience its just a matter of time before the valve stem seals leak. It seems to be just poor seal design/engineering. Prolonged idling time also seems to accelerate the problem (excessive heat).
Old 05-16-2013, 03:17 AM
dolfan13's Avatar
Mein Auto: 545i
Bmwoem1 ,I'm modded a stock tstat to run 95c.As you know this is 10c cooler than stock.Ive been running this way for 6k miles with no apparent problems.My UAO shows no unusual wear.I did this in an attempt to slow down seal degradation.All the seals.Dont know if it will help but let me know what you think.Thanks.
Old 05-16-2013, 03:37 AM
ferny ferny is offline
Mein Auto: 06' BMW 650i
How did you do that mate?
// 06 650i, aFe Intake, M310 Avant Garde Wheels
// M Driving School
Old 05-16-2013, 04:09 AM
dolfan13's Avatar
Mein Auto: 545i
Learned this trick from LS engine vette guys.Took the element off the pin of the tstat and put a shim down the hole.Had to play with shim length to get valve seated exactly where I wanted.
Old 05-16-2013, 04:18 AM
dolfan13's Avatar
Mein Auto: 545i
Another approach http://www.bimmerfest.com/forums/sho...d.php?t=665965 page 48.Very large thread on this. A certain member stated he was having custom TStats made but that seems to have vanished.??Anyway a couple of different ways.To lower operating temps on M62 seemed to be a common mod.I seem to be one of the first on here with a n62?
Old 05-16-2013, 04:23 AM
Past Sponsor
Mein Auto: X3
I don't think this will help because its the engine oil that needs to be cooler. The oil cooler has its own thermostat. So the lower temp coolant thermostat may delay the time it takes for the oil to get hot, but eventually the oil will reach the same temperature as it always did. Also, it is the exhaust valve stem seals that fail, not so much the intake side. Due to the hot exhaust gasses squeezing past them, the exhaust valves run at a higher temp than the intake, which why those seals fail first. The lower temp thermostat should not affect the combustion chamber temp/exhaust gas temp too much (if it did, you would notice a decrease in power/mileage). Then again... The thermostat mod can't hurt your engine so it could only help
  #25
Old 05-16-2013, 04:37 AM
dolfan13's Avatar
Mein Auto: 545i
Thanks Bmwoem1.I have noticed a nice improvement on throttle response after complete warm up.Also hoping it might help with other seals.Sorry to keep hounding but do you think more frequent oil changes or other types of oil will help with valve seals?Thanks again.Oh Im actually in a 545i but as you know all the same but my car didnt get an oil cooler.I have looked at after market.
Closed Thread
