Old 04-30-2013, 07:45 PM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
My N54 has a sticking lifter
I thought it was the bottom end of the engine but I saw a post from someone with the same issue and they replaced the bearing and as soon as they rebuilt it the sound stayed and it ended up being a lifter.
How had is it to replace?
If you like customer service. Don't look beyond a BMW.
Old 05-01-2013, 04:26 PM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
Doubt few have done that yet. The internet says try oil additives first (that was my guess and Google verifies).
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 05-01-2013, 06:51 PM
the noise has gone for now I think it happens every oil change its just been 5 month since the last one.
Old 05-01-2013, 06:58 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Wait - happens just before every oil change?
And if so, what's the mileage interval?
Old 05-01-2013, 06:59 PM
What spec & brand oil do you use?
Old 05-01-2013, 07:34 PM
It happens just after oil change and its serviced at BMW and its done every 8k
I thought it was a new thing when I put the cob on just after the oil change last week but then I remembered this crap happened when I had my oil change last time.
Old 05-02-2013, 12:29 AM
unrealii unrealii is offline
Mein Auto: 2009 335 6MT 'vert
I thought I remember reading somewhere you can just rev the engine at a low RPM to un stick it. I'd research that, might be a cheap fix.
2009 335i 6MT M-Sport AW/CR Convertible
2002 Toyota 4Runner 4wd
Old 05-02-2013, 02:50 AM
Banned
Mein Auto: 2007-335 HTC
just drive it hard and get the oil pumping. like shifting at 6 grand a couple of times, once the engine is warmed up
Old 05-02-2013, 05:07 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Here you go...
Ticking noise cure.pdf
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 05-02-2013, 05:58 AM
Yeah its not the rattle this sounds like a bearing has gone in the bottom end but its really coming from the top end.
MP3_E46's Avatar
Code/wrench Monkey
Since you have ~170K+ (right?) I'd be tempted to run it with some Marvel Mystery Oil or similar for a week before the next oil change. Synthetic is not meant to sludge but by that mileage one could imagine build up here and there causing parts to stick a little. Of oil additives designed to really clean internals can release large particles and cause real damage but I think that's rare. I've heard of cleaning causing blue smoke because it cleaned off carbon that was sealing at the rings
Just looked up used prices on N54 blocks and they are still pretty pricey
Old 05-02-2013, 06:02 AM
here this thread explains it. (listen to the clip its not the tapping of the valve train but the clunk sound that I am on about).
http://www.e90post.com/forums/showthread.php?t=667559
My cars got 148 close to now because I have not had weather to do anything but go to work and back and I have been running the X1 that's only got 3k miles on it since last October
Old 05-02-2013, 08:36 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
replacing a lifter is hard and requires special tools to remove and replace the camshafts. Most camshafts on N54s are hollow. Without the special tools you can break the cams easily. The tools are available for rental so if you are motivated and a fairly skilled DIYer, I would try it if all else fails.
