E30 (1982 - 1993)
Old 05-01-2013, 07:56 AM
Salicars Salicars is offline
Mein Auto: 3 series
Obd for e30
I have a 1985 318i. It starts fine and immediately stalls. I've replaced a ton of parts. No joy. Not interested in a stomp test because i understand i need to solder in a light in the cluster to perform it. I am sure the old plastic will explode if i touch it. I would rather use the diagnostic connector. My question: it's a 15 pin and one apparently doesn't exist. Does the 20 connector fit into this 15 pin as it appears to the same as the 20 with a side removed. I would need to buy one and didn't want to waste money on the wrong connector.
Old 05-01-2013, 08:25 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
I bet its a vacuum leak after the AFM. Had the same problem with my 2.7 I had. It'd start up rev up a little bit then immediately die. Sealed the intake boot with electrical tape and solved my problem.. so I bought a new boot the next day and it ran good again.
As far as I know.. no diagnostic connector. That 15 pin connector is only for resetting service life of your oil and pads I think.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
