Old 05-01-2013, 04:26 PM
jelliotlevy jelliotlevy is offline
Mein Auto: 2011BMW 335i, Honda S2000
2011 335i - The dreaded HPFP
This came as a surprise to me. Our 2011 335i, now at 24,900 miles. It had been running faultlessly, till Monday. Out of the blue, while quietly trolling at about 35 mph, I got the yellow symbol of a 1/2 engine, and a warning of reduced power. The car would run normally if I drove like Grandma, but would not produce power if I hit the gas hard. Example: At 50 mph, hard throttle would produce about 5500 rpm (probably 2nd gear), a lot of noise and very little acceleration. Smooth cruising at 60 mph felt normal.
The dealer tested the High Pressure Fuel Pump, and found it faulty. Replacement has cured the problem. The car's date of manufacture is November 2010, so it certainly has the new design fuel pump. I find myself wondering if this is just a random failure, or if faulty fuel pumps are still being discovered. I especially worry, since the Government, in its wisdom, and under the influence of the Corn Lobby, is considering raising the ethanol content of our gasoline from the current 10% up to 15%. I am much suspicious that ethanol has been the culprit in the HPFP saga. Any thoughts out there?
Old 05-01-2013, 05:02 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Originally Posted by jelliotlevy View Post
I find myself wondering if this is just a random failure, or if faulty fuel pumps are still being discovered. ... I am much suspicious that ethanol has been the culprit in the HPFP saga. Any thoughts out there?
Yes. An HPFP failure is not necessarily THE HPFP failure.
The cause of the chronic problem was long ago isolated to be cavitation, ultimately cured by a pump redesign and a software fix to prime the low-pressure (suction) side of the pump before engine start.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 05-02-2013, 06:19 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Yeah, pumps is pumps. Eventually, as with all mechanical items, they'll all fail (HPFP, LPFP, water pump, etc.). You just got the left side of the bell curve on yours.
