E34 (1989 - 1995)
Old 05-02-2013, 06:23 AM
rdc rdc is offline
Russell
Mein Auto: 1995 525iA
# hours to replace heater core?
Looks like mine is starting to leak. Guess I will have my indy do it. Coolant/water is dripping under the car on right drain and the coolant light came on this morning. Noticed it a few days ago.
I will turn heat all the way to off. I don't think that stops flow to the heater core though. Anyone know?
May do the bypass trick. Guess I will need to search for it.
1995 525i auto, 1/95 build, EAT chip, abt 239K miles, , HID, Lumbar, Oxford Green/Parchment, rebuilt trany @ 211K
Old 05-02-2013, 07:07 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
If your heater valve is working correctly, then turning the temp knobs to full cold will stop the flow of current through the heater core and thus stop your leak at least for the summer when you don't need heat.
I recently had mine done by my indy mech. It was $635 including a new cabin filter. It was worth EVERY penny. I saw the car when it was disassembled and man, what a nightmare. Some here will encourage you to do it. It can be done, but it is a major job if you choose to do it.
Good luck.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-02-2013, 07:23 AM
rdc rdc is offline
Russell
Good luck.
You are the man! I like your approach.
Old 05-02-2013, 05:49 PM
txrealtor txrealtor is offline
Mein Auto: '95 525it '95 525i/M
Good luck.
+1000000000000000! Have it done!! While it can be a DIY, if you can afford to get it done, then do it!!!
1995 525it/5 98,000 miles
1995 525i 123,000 miles
1995 530i
Old 05-03-2013, 02:04 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
bit of a headache, but not too bad if you have a weekend spare. a good 4 or 5 hours tho
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 05-05-2013, 07:05 PM
djchuck djchuck is offline
Mein Auto: 1995 525i Sedan
I saw a tutorial on it. They said that it depends on "how" you do it... If you take apart the entire dash, gives you more room but adds hours. You can just take out the console saves time but tightens up the work space and makes it a bit more of a headache.
+1 to having someone else do it.
Old 05-07-2013, 07:02 AM
rdc rdc is offline
Russell
Might remove the passenger side carpet covered panel to see if I can seen anything regarding the heater core. You know, like you are changing the cabin filter which I also need to do. Doubt if I can as there is a cover over the core. Just sort of thinking out loud. My passenger side under car drain is where antifreeze is coming out. Makes me think/hope it is just an O ring on that side. I may order all the O-rings and dive in.
It does not seem to be too much trouble to get the lower dash apart. I have had the console, driver's side under panels, glove box OBC and radio out before. However, never had the heater controls (slide type) out. Not sure if there are issues there??
Even if i decide not to fix it myself. I can save a bunch of labor if i remove and replace all the interior parts I know i can handle. My shop chanrges by the hours spent on a job, not a flat rate book. These guys are good.
Thoughts?
Old 05-07-2013, 03:31 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
I did it. The biggest PITA is dismantling everything to get to it.
I practiced in a yard before i attempted it.
I can pretty much do it by memory and a beer.
Yes if you have the cash to spend on a shop I'd do it too.
_______________________________________
Content Writer - FCPEURO
95 e34 525 5 spd S52 Swap...Sold
01 e38 740i msport (under restoration )
