E36 (1991 - 1999)
Old 05-02-2013, 06:55 AM
norcal318 norcal318 is offline
Mein Auto: 95 318 is
Post 318 is
Is it a good idea to switch from the duel mass flywheel to a regular flywheel what is the pros and cons
Old 05-02-2013, 07:57 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Misleading title. A lightweight single mass flywheel will make it harder to shift, since the flywheel carries angular inertia, it will help keep the engine from stalling. It is also un-sprung weight, so lightening the flywheel will make the car a bit more responsive.
You will also typically get chatter from a lightweight flywheel so folks who aren't used to that usually ask if they did something wrong. The dual mass flywheel sometimes has some interesting components that soften the changes caused by shifting, which eases the wear on accessory components like air conditioning.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 05-02-2013, 08:28 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Re: 318 is
Rotational mass perhaps? How would a flywheel be unsprung mass? Its mass is carried on the vehicle chassis which is definitely sprung.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 05-02-2013, 08:32 AM
petriej's Avatar
Yes, that.
GGC BMW CCA #443004
Join the BMW CCA!
